+ Post New Thread
Results 1 to 13 of 13
  1. #1
    Full Member level 4
    Points: 2,273, Level: 11
    joe1986's Avatar
    Join Date
    Jan 2008
    Posts
    207
    Points
    2,273
    Level
    11
    How to check if DTMF IC is working properly?
    how can i check if my DTMF IC is working properly or not...........any idea????
  2. #2
    Advanced Member level 5
    Points: 13,542, Level: 27
    nandhu015's Avatar
    Join Date
    Feb 2006
    India
    Posts
    1,960
    Points
    13,542
    Level
    27
    Blog Entries
    18
    Re: DTMF CHECK
    Simple
    Connect it to a telephone line.
    A epabx will also do
    regards
    Nandhu
    1 members found this post helpful.
  3. #3
    Newbie level 2
    Points: 866, Level: 6
    Join Date
    Feb 2008
    Posts
    Points
    866
    Level
    Re: DTMF CHECK
    Quote Originally Posted by joe1986
    You need to feed it two sinewave frequencies, one from the lower group and one from the upper group of 4 frequencies simultaneously and verify the correct 4-bit result at the digital decoded output of the chip. Depending on the chip type, you may need to take the 2 dB +/- 1 dB signal level difference into account.
    Good luck !
    Hans
    •   Alt13th February 2008, 21:26
      advertising
  4. #4
    Full Member level 4
    joe1986's Avatar
    Join Date
    Jan 2008
    Posts
    207
    Points
    2,273
    Level
    11
    Re: DTMF CHECK
    hi nandhu015 .................do u have any diagram which shows how to connect it to the telephone???
  5. #5
    Junior Member level 3
    Points: 1,222, Level: 7
    Join Date
    Aug 2007
    Hanoi City, Vietnam
    Posts
    31
    Points
    1,222
    Level
    7
    DTMF CHECK
    Which DTMF IC do you use?
    You can connect it with a MT8888 to check if it transmit/receive right or wrong.
    •   Alt14th February 2008, 03:44
      advertising
  6. #6
    Full Member level 4
    joe1986's Avatar
    Join Date
    Jan 2008
    Posts
    207
    Points
    2,273
    Level
    11
    Re: DTMF CHECK
    the IC IS DTMF 8870..................ITS ACTING AS A DECODER
    •   Alt14th February 2008, 08:20
      advertising
  7. #7
    Banned
    Points: 8,931, Level: 22
    Join Date
    Jan 2007
    Posts
    943
    Points
    8,931
    Level
    22
    Re: DTMF CHECK
    Have alook at this site : http://www.electronicsforu.com/EFYLi.../CI-2-DTMF.pdf .
    What ever numbers you dial from the phone, should show up on the LEDs.
    Regards,
    Laktronics
  8. #8
    Full Member level 4
    joe1986's Avatar
    Join Date
    Jan 2008
    Posts
    207
    Points
    2,273
    Level
    11
    Re: DTMF CHECK
    THANK a lot doctor laktronics........................DO U HAVE THE MAY 07 edition of EFY..........there's a file called "WIRELESS TEXT MESSAGING OVER MOBILE/LANDLINE...........????
  9. #9
    Full Member level 1
    Points: 2,332, Level: 11
    segmex's Avatar
    Join Date
    Oct 2006
    Posts
    114
    Points
    2,332
    Level
    11
    DTMF CHECK
    use oscope to view the dtmf signal ..
  10. #10
    Banned
    Join Date
    Jan 2007
    Posts
    943
    Points
    8,931
    Level
    22
    Re: DTMF CHECK
    I just remebered, your 5V supply should not have a safety earth connection, since telephone line is already earthed through +ve of the battery. I don't have the May Issue, you may get it from their site?
    Regards,
    Laktronics
    •   Alt14th February 2008, 15:21
      advertising
  11. #11
    Full Member level 4
    joe1986's Avatar
    Join Date
    Jan 2008
    Posts
    207
    Points
    2,273
    Level
    11
    Re: DTMF CHECK
    hi .....doctor laktronics there is one problem ...........the site is asking for username and password of subscribers..............actually i subscribe for ELEKTOR ELECTRONICS...........and not EFY ...................are you a subscriber???
  12. #12
    Join Date
    Aug 2007
    Hanoi City, Vietnam
    Posts
    31
    Points
    1,222
    Level
    7
    Re: DTMF CHECK
    Have you made a test board?
    If you have, it's so easy.
    Connect your phone line to the input of 8870. Call from other phone. Hook up the phone which connect with 8870. Then press some numbers from the caller phone. If your test board can receive what you press , it's working well. That's all.
    Regards.
  13. #13
    Full Member level 4
    joe1986's Avatar
    Join Date
    Jan 2008
    Posts
    207
    Points
    2,273
    Level
    11
    Re: DTMF CHECK
    whts a TEST BOARD AND HOW TO MAKE IT???
