thx505
Newbie level 2
I'm trying to simulate a birdcage coil for this I need a little bit more ideas about the theoretical part of that coil. I will describe what i mean i already understood and maybe you can give me the last input to break through to a better level of understanding.
So in my opionon it works like that:
1.
The Birdcage coil consists of a number of sections which are designed as an Low-Pass, High-Pass or Band-Pass. So the number of the rungs is identical to the number of sections. Each of this section produces a Phase Shift of the current flow through the rungs. The goal is to approximate a cos or sin-distribution over the "surface" of the coil (for the homogenous transverse B-Field). The overall Phase has to be N*2*3,14 and in this case you have resonance. But at which frequency?
Do you use the lumped elements to bring it to a specific frequency?
Where I can something about to caculate them?
Is THIS independent from the number of ports or did it only work if you use a minimum nuber of two ports?
2.
Now you can use two ports with a 90° phase shift to get a circular polarized field. In my simulation that works fine. But now the question: is there a difference between using this two ports and a two-channel coil?
What about the concept of multi-channel coils? Are there more Ports to get a more homogenous B-Field or is this another concept?
I hope somebody is able to give me another input. Maybe this sounds a little bit confusing but I think it's just because I'm not sure how to bring all this ideas together!
thx
1.
2.
thx
