Antonios
Banned
Dear All
when I try to export PDIF from PCAD there is some warning as flow How I Can Fix this Warning Becouse I Has Problem when i import this file in the Capture"Schmatic Tool of Cadance"
the warning
P-CAD 2000 Schematic Version 15.10.17 PDIF Translator
Sheet1:
Warning: Translating polygon object near (537.0mil, 62.0mil) as Master Designer lines.
Warning: Translating polygon object near (462.0mil, 0.0mil) as Master Designer lines.
Warning: PID too long at line 6830. Truncated.
Warning: Translating polygon object near (-387.0mil, -62.0mil) as Master Designer lines.
Warning: Translating polygon object near (-387.0mil, -112.0mil) as Master Designer lines.
Warning: Translating polygon object near (-350.0mil, -73.0mil) as Master Designer lines.
Warning: Translating polygon object near (-491.0mil, -194.0mil) as Master Designer lines.
Warning: Translating polygon object near (387.0mil, -50.0mil) as Master Designer lines.
Sheet2:
Warning: Translating polygon object near (412.0mil, -50.0mil) as Master Designer lines.
Warning: Translating polygon object near (412.0mil, -100.0mil) as Master Designer lines.
Warning: Translating polygon object near (325.0mil, -123.0mil) as Master Designer lines.
Warning: Translating polygon object near (465.0mil, -197.0mil) as Master Designer lines.
Warning: Translating polygon object near (409.0mil, -540.0mil) as Master Designer lines.
Warning: Translating polygon object near (409.0mil, -590.0mil) as Master Designer lines.
Warning: Translating polygon object near (322.0mil, -613.0mil) as Master Designer lines.
Warning: Translating polygon object near (462.0mil, -687.0mil) as Master Designer lines.
Sheet3:
Warning: Translating polygon object near (-400.0mil, 60.0mil) as Master Designer lines.
Warning: Translating polygon object near (-400.0mil, -60.0mil) as Master Designer lines.
Warning: Translating polygon object near (160.0mil, -38.0mil) as Master Designer lines.
Warning: Translating polygon object near (160.0mil, 87.0mil) as Master Designer lines.
Warning: Translating polygon object near (668.0mil, 542.0mil) as Master Designer lines.
Warning: Translating polygon object near (793.0mil, 575.0mil) as Master Designer lines.
Warning: Translating polygon object near (622.0mil, 575.0mil) as Master Designer lines.
Warning: Translating polygon object near (497.0mil, 425.0mil) as Master Designer lines.
Warning: Translating polygon object near (668.0mil, 292.0mil) as Master Designer lines.
the warning
Sheet1:
Sheet2:
Sheet3:
