The difference between weak pull down/pull up and strong pul
EDA_hg81
Advanced Member level 2
strong and weak pull ups
Thanks.
weak pullup and strong pull up
less current goes in to the pin, I would not recomend to use them use , put one resistor at the pin will save you a lot's oh headache during debuging
Added after 2 seconds:
    EDA_hg81
Re: weak pullup and strong pull up
thanks for the reply
A weak pullup will hold a value on a pin while all other drivers are in tri-state, and can be over-ridden by the value of the driver, once it starts driving. A strong pullup cannot be over-ridden by the driver, and will cause contention.
