+ Post New Thread
Results 1 to 12 of 12
  1. #1
    Member level 1
    Points: 1,331, Level: 8
    Join Date
    Jun 2007
    Posts
    33
    Points
    1,331
    Level
    8
    pcb component placement
    Hi
    Can any one tell me how do we decide the placement of components on the PCB i.e. where to route power signals where to route clock signals and how to route digital and analog signals?
  2. #2
    Member level 2
    Points: 1,562, Level: 9
    Join Date
    Jun 2006
    Posts
    42
    Points
    1,562
    Level
    9
    Re: PCB component placement
    1-(placement of components) depend on the components type like analog, digital, noisy, senestive, power,..
    2-(route power signals) top and bottom layers, and internally in power layer
    3-(route clock signals and how to route digital and analog signals) in internal signal layers and assign one power layer(GND,DGND,AGND,VCC,VDD) for each signal layer,
    Generally don't route high speed signal (clock,..) in top or bottom but you can route low speed signal in top and bottom, separate between high speed signal layers by power layers
    •   Alt3rd February 2008, 07:58
      advertising
  3. #3
    Member level 1
    Join Date
    Jun 2007
    Posts
    33
    Points
    1,331
    Level
    8
    Hi
    Can you tell me how to place analog, digital, noise and power circuitry
  4. #4
    Advanced Member level 3
    Points: 9,210, Level: 22
    cyberrat's Avatar
    Join Date
    Jun 2001
    In the sewers of the U.K.
    Posts
    858
    Points
    9,210
    Level
    22
    not in a simple forum reply, it takes a lot more than just questions here.
    Read through the forum, see what others asking similar questions have been told.
    Buy some books.
    Buy some training.
    Read lots.
    Please do not PM me questions that are better asked in the PCB forum :)
  5. #5
    Junior Member level 1
    Points: 1,489, Level: 8
    Achievements:
    7 years registered
    Join Date
    Dec 2006
    Posts
    15
    Points
    1,489
    Level
    8
    ***Some Points to be consider at the time of Board Layout
    1).All components should be placed with an appropriate functional group and their tracks routed within their designated PCB area.
    Arrangement of Functional Groups on PCB
    2) Place ground plane(s) under all components and all their associated tracks a continuous ground plane with no avoidance in IC package or I/O connector area is recommended.
    Added after 4 minutes:
    Send me your mail id ill mail you the placement block created by me for the Digital,Analog,Power and noisy group.
    1 members found this post helpful.
    •   Alt4th February 2008, 12:53
      advertising
  6. #6
    cyberrat's Avatar
    Join Date
    Jun 2001
    Posts
    858
    Points
    9,210
    Level
    22
    Yes, what Matthewsam says, I always take groups of components, sub sections of the circuit and group them together around the board outline.
    It helps you to think about where they will all fit, also ensures that you have all the parts together & dont forget anything.
  7. #7
    Member level 5
    Points: 1,833, Level: 9
    Raju_epigon's Avatar
    Join Date
    Feb 2008
    Posts
    80
    Points
    1,833
    Level
    9
    Placement of component is depends on the circuit flow
  8. #8
    cyberrat's Avatar
    Join Date
    Jun 2001
    Posts
    858
    Points
    9,210
    Level
    22
    The way I find best is to get all the components that will be on a board, put em in a little pot.
    Cut out paper template of board size & cover it in PVA glue.
    Shake pot, do little dance, pour pot onto paper & rattle till all components are stuck down.
    Then go to CAD workstation & copy it.
    See that its awful & then start again following the flow of the circuitry, keeping the major high current & important/sensitive tracks in logical order, putting all connectors where they need to go etc.
    Remember, the dance is important! :D
  9. #9
    Member level 1
    Points: 1,592, Level: 9
    Achievements:
    7 years registered
    Join Date
    Oct 2007
    Posts
    40
    Points
    1,592
    Level
    9
    Pls check this link.I found it helpful for me.
    http://www.edaboard.com/viewtopic.php?p=930679#930679
    •   Alt14th February 2008, 07:26
      advertising
  10. #10
    Full Member level 3
    Points: 2,949, Level: 12
    Achievements:
    7 years registered
    Join Date
    Jun 2007
    India
    Posts
    172
    Points
    2,949
    Level
    12
    the placement of components may be a critical part as mentioned above try to group all the components in the circuit such as power supply ,analog & Digital.
    while placing the components make sure that routing the tracks is easier and simpler inorder to avoid more complications during routing.Try to maitain a minimum distance between the analog and digital circuits and also the power supply parts
  11. #11
    Full Member level 3
    Points: 3,580, Level: 14
    Achievements:
    7 years registered
    Join Date
    Nov 2005
    Bg
    Posts
    187
    Points
    3,580
    Level
    14
    Look at this:
    http://www.edaboard.com/download.php?id=141974
    It is about the all questions in PCB design - placement, routign, etc.
  12. #12
    Full Member level 4
    Points: 2,935, Level: 12
    Join Date
    May 2004
    Posts
    227
    Points
    2,935
    Level
    12
    Hi Guys
    i am doing a board with 3 processors, a fpga and 2 cplds. working at 50mhz. the layer stack up is layer 1, internal plane1(VCC), layer 2, layer 3, layer 4, internal plane(GND), bottom layer. Its a kind of dual channel system, I have attached the block diag/ placement of the components. I am planning to routing data and and add in layer 3 and layer 1. Would that be appropriate and what kind of termination i would be better to use with such kind of routing. This is my first big design hence asking for some feedback.
    routing of add and data bus would look like C shape.
    thanks in advance
    tama[/img]
