+ Post New Thread
Results 1 to 16 of 16
  1. #1
    Advanced Member level 1
    Points: 4,132, Level: 15
    Join Date
    May 2006
    Posts
    414
    Points
    4,132
    Level
    15
    24 to 12 volts regulators
    ASA to ALL
    im working on micronontroller based circuit .... circuit will drive by car bettery 12V or 24V.... in case of using simple 7805 regulator it become hotter though i screw heat sink with that regulator. pls share me some idea to make some reliable regulator cicuit. wich remain cool upto 3 amps.
    regards
  2. #2
    Advanced Member level 5
    Points: 14,575, Level: 29
    blueroomelectronics's Avatar
    Join Date
    Sep 2006
    Toronto, Canada
    Posts
    1,686
    Points
    14,575
    Level
    29
    2 transistor black regulator
    Try an National Semiconductor Simple Switcher.
    •   Alt27th January 2008, 20:24
      advertising
  3. #3
    Full Member level 5
    Points: 4,033, Level: 14
    Join Date
    Mar 2002
    Posts
    301
    Points
    4,033
    Level
    14
    3amps regulators
    Hi. You may use LM2576-5.0(or -ADJ). Look here:
    \http://www.national.com/mpf/LM/LM2576.html
    Best Regards.
  4. #4
    Join Date
    May 2006
    Posts
    414
    Points
    4,132
    Level
    15
    7805 10a regÜlatÖr
    thx both of you pal..... i appriciate if some one give some idea using convetionel regulator ICs and transistors.
    •   Alt28th January 2008, 07:44
      advertising
  5. #5
    Full Member level 2
    Points: 2,951, Level: 12
    Join Date
    Jul 2006
    Bucharest, Romania
    Posts
    142
    Points
    2,951
    Level
    12
    make 12 and 5 volt ciruct from 24 volts
    Try a Linear Technology step down switcher
  6. #6
    Advanced Member level 3
    Points: 6,212, Level: 18
    Join Date
    Apr 2006
    Hyderabad, India.
    Posts
    789
    Points
    6,212
    Level
    18
    24 volts 5 volts
    Quote Originally Posted by drbizzarow
    At 3amps load current it is better to use smps, then conventional regulators,with specific need to improve on enery losses, uising power from a car battery.
    Sarma
    •   Alt28th January 2008, 08:11
      advertising
  7. #7
    Member level 3
    Points: 2,535, Level: 11
    Join Date
    Feb 2006
    Posts
    54
    Points
    2,535
    Level
    11
    3a regulators
    use LM2595 regulator with 100khz switching supply.
    or use 7805 with any 10A bipolar transister as driver.
  8. #8
    Points: 904, Level: 6
    Join Date
    Jan 2008
    Posts
    7
    Points
    904
    Level
    7805 regulator circuit
    I have the circuit.
    I can send you my circuit design.
    Send me your e-mail. pls
    ASA to ALL
    regards
  9. #9
    Join Date
    May 2006
    Posts
    414
    Points
    4,132
    Level
    15
    12v 3a regulator circuit
    thx my email is hatetoshare@hotmail.com u can private msg me thx in advance
  10. #10
    Join Date
    May 2006
    Posts
    414
    Points
    4,132
    Level
    15
    7805 design
    hi tukul12....
    im waiting for your mail
  11. #11
    Junior Member level 2
    Points: 1,767, Level: 9
    Join Date
    Jan 2004
    Posts
    23
    Points
    1,767
    Level
    9
    24 to 12 regulators
    don't sure about amps and volts, but maybe this will be useful The 2-transistor Black regulator
    http://www.romanblack.com/smps/smps.htm
  12. #12
    Junior Member level 1
    Points: 1,073, Level: 7
    Join Date
    Aug 2007
    Posts
    19
    Points
    1,073
    Level
    7
    24 volts vs 5 volts
    Hi you can use PQ30RV31 is a nice and cheap LVD 3A 1.5 to 30 volts from SHARP . gogle it
    regards
  13. #13
    Join Date
    May 2006
    Posts
    414
    Points
    4,132
    Level
    15
    tps5430 smps circuit
    thx CapBlack .....
    let me chk the local market this chip avilabelity... and cost.
  14. #14
    Points: 32,456, Level: 44
    Join Date
    Apr 2002
    USA
    Posts
    3,942
    Points
    32,456
    Level
    44
    7805 regulator 3a
    Hi drbizzarow, Any linear regulator (such as PQ30RV31) will get just as hot as your original 7805 design.
    To reduce power dissipation (heat), you must use a switching regulator, as suggested by several folks above.
    Possibly helpful: National Semiconductor has an on-line tool for designing and simulating power supplies, and for buying a kit of parts. You may need to register, but it's free.
    http://www.national.com/appinfo/webe...=power&step=0A
    •   Alt2nd February 2008, 11:14
      advertising
  15. #15
    Points: 11,875, Level: 26
    bobcat1's Avatar
    Join Date
    Jul 2002
    Posts
    Points
    11,875
    Level
    26
    7805 3a circuit
    Hi
    Use TI TPS5430 single SO8 device with up to 3A of current and 9~30V input range
    All the best
    Bobi
  16. #16
    Join Date
    May 2006
    Posts
    414
    Points
    4,132
    Level
    15
    reduce 12 volts to 5 volts
    thx echo47... u r right my circuit will drive by 12 volt car battery system or 24 volt car battery system.... so main problem is to reduce heat.
