+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Full Member level 3
    Points: 2,238, Level: 10
    Join Date
    Dec 2006
    Posts
    188
    Points
    2,238
    Level
    10
    Convolution
    What is the differance between convolution and correlation
    •   Alt26th January 2008, 10:51
      advertising
  2. #2
    Newbie level 5
    Points: 941, Level: 6
    Join Date
    Jan 2008
    Posts
    8
    Points
    941
    Level
    Re: Convolution
    Quote Originally Posted by sundarmeenakshi
    digital convolution is called correlation
    1 members found this post helpful.
  3. #3
    Full Member level 1
    Points: 2,396, Level: 11
    asoom's Avatar
    Join Date
    Dec 2007
    jordan
    Posts
    100
    Points
    2,396
    Level
    11
    Re: Convolution
    correlation is used to compare the similarity of two signals, the result is a signal that shows this similarity and reaches its maximum at the time when the two signals match best. correlation can be used to measure the delay of a certain system.
    convolution is used to compute the output of a certain linear system when a certain input signal is applied to it. this is done by applying convolution between the input signal and the impulse response of the system
    2 members found this post helpful.
  4. #4
    Member level 3
    Points: 1,180, Level: 7
    Join Date
    Jan 2008
    Posts
    61
    Points
    1,180
    Level
    7
    Re: Convolution
    From mathematical point of view convolution of two function is:
    x(t)*y(t)=∫x(Θ)y(t-Θ)dΘ
    and correlation is
    E[x(t)y(t)]=∫x(Θ)y(t+Θ)dΘ
    •   Alt27th January 2008, 08:59
      advertising
  5. #5
    Member level 1
    Points: 1,462, Level: 8
    Join Date
    Aug 2005
    Posts
    39
    Points
    1,462
    Level
    8
    Re: Convolution
    Convolution is the operation / transformation that governs the i/p - o/p relationship in a LTI system.
    Correlation is a statistical measure of how similar two waveforms or random processes are.
    In the case of a matched filter, correlation and convolution becomes the same.
  6. #6
    Junior Member level 1
    Points: 960, Level: 7
    Join Date
    Jan 2008
    Posts
    15
    Points
    960
    Level
    7
    Convolution
    convolution is specifically used for the multiplication of continous and discrete time signal in time domain and valid for LTI system but correlation is matching and comparision of signal and there are two types auto and cross correlation and its example in missile imaging
    Added after 22 seconds:
    convolution is specifically used for the multiplication of continous and discrete time signal in time domain and valid for LTI system but correlation is matching and comparision of signal and there are two types auto and cross correlation and its example in missile imaging and using correlators and matched filters for taht
  7. #7
    Full Member level 4
    Points: 2,684, Level: 12
    Join Date
    Jan 2008
    Bangalore,India
    Posts
    207
    Points
    2,684
    Level
    12
    Re: Convolution
    Convolution of two signals can be interpreted graphically as folows:
    supose you take convolution between x(t) and y(t). Then in t domain just reverse the signal y(t) i.e. plot the signal y(-t). Now translate the signal y(-t) from -∞ to Γ. The overlap area is the convolution between x(t) and y(t). at the point Γ.
    On the otherhand the correlation is the same thing, only thing is that, you dont have to invert the signal y(t) in t domain. Translate y(t) itself from -∞ to Γ. The overlap area gives the correlation between these two signals.
    •   Alt30th January 2008, 08:12
      advertising
  8. #8
    Newbie level 6
    Points: 1,093, Level: 7
    Join Date
    Nov 2007
    Posts
    14
    Points
    1,093
    Level
    7
    Convolution
    Completly agree with asoom
  9. #9
    Full Member level 2
    Points: 1,833, Level: 9
    Join Date
    Sep 2007
    Posts
    143
    Points
    1,833
    Level
    9
    Convolution
    Correlation + Shifting = Convolution
    This is the difference between the both.
