+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Full Member level 5
    Points: 2,527, Level: 11
    Join Date
    Mar 2007
    Karachi, Pakistan
    Posts
    262
    Points
    2,527
    Level
    11
    80x86 programming
    hi
    is it possible to program 80x86 microprocessor using C language..??
    if yes
    then please give me some usefull tutorials about it...
    if no
    then plzz send me tutorials of assembly programming of 80x86
    •   Alt23rd January 2008, 18:02
      advertising
  2. #2
    Super Moderator
    Points: 239,611, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,515
    Points
    239,611
    Level
    100
    Re: 80x86 programming..??
    Hello,
    if you intend to use x86 for embedded applications, OpenWatcom (www.openwatcom.org) would be flexible tool and powerful tool. Many of todays C compilers don't support real mode 8086, e. g. microsoft has ended it with MSVC V1.5 in 1999. Probably the best professional compiler for real mode X86 is Paradigm (www.devtools.com) , a Borland C successor. I use it with Lantronix EX processors.
    I guess, there are lots of tutorials, but I don't watch for. In the embedded field, some companies supply hardware platforms, e. g. X86 processor modules. Some have excellent reference applications. If you already have your X86 hardware platform and your field of application, you should search in it's vincinity.
    Regards,
    Frank
    •   Alt23rd January 2008, 20:07
      advertising
  3. #3
    Banned
    Points: 2,735, Level: 12
    Join Date
    Feb 2006
    Bandar Abbas
    Posts
    161
    Points
    2,735
    Level
    12
    this book can be helpful:
    80X86 IBM PC and Compatible Computers by Mazidi, Muhammad Ali
    •   Alt23rd January 2008, 20:12
      advertising
  4. #4
    Member level 4
    Points: 1,817, Level: 9
    Join Date
    Sep 2005
    Belfort, France
    Posts
    77
    Points
    1,817
    Level
    9
    I doubt if u would find a freeware compiler, since 8086 has long been obsolete. Either move to 386 (atleast), buy a professional tool (which I know u guys would not) or stick with microcontrollers.
  5. #5
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,515
    Points
    239,611
    Level
    100
    Hello,
    although you doubt, OpenWatcom is freeware or more exactly, open source. 8086 isn't obsolete in so far as new embedded processors of this family have been designed in the last years. I admit, that the motivation for using X86 may be in part from developers habit, but they aren't so bad at all. If you prefer, you could reagard them like veteran cars on the highway, but some have been tuned considerably.
    Regards,
    Frank
    •   Alt23rd January 2008, 22:44
      advertising
  6. #6
    Banned
    Join Date
    Feb 2006
    Bandar Abbas
    Posts
    161
    Points
    2,735
    Level
    12
    You can use 8086 emulator I've got it
