pankaj kumar
Newbie level 3
Re: cc2500 and 8051
pankaj kumar
thanks and regardshi
i think the output pins can be programmed to show the status of receive buffer
when the receive buffer is full, the output pin (i think SO) will change the status. now if you are using the hardware spi of atmega it will be difficult to monitor unless you do not connect the pin to the interrupt pin. and when you are communicating eith the rf module, make sure the interrupt be disabled and enable the same after the communication with module. so when the module memory is full, the system will get interrupted and you can use the data. if you can program the gpio pins as the interrupt source, there will not be much complexity.
regards
ml
pankaj kumar
