how to calculate time(seconds) with 8051 timers????
info_req
Member level 5
Pakistan
8051 2 second timer
dear all,
i want to calculate time using 8051 timers, clock is 12MHz. i.e how to program timer for 1000000???
can i use timer0 and timer1, so that they count more than 16 bit????
thanks
timers in 8051
Dear Friend
you can use any timers
but the maximum count you can get is only 65535+1
because the timer is a 16 bit timer
you can use other methods to get your required counts
but if you need exat timimg you should take care
ml
    info_req
mcs51 use timer
use timer in a loop
    info_req
how to calculate 8051 timer
as mentioned, use two timers in loops. which means make a 65535 counts for the counter in the internal loop update the count for the timer in the external loop by 1. and so you'll achieve number of counts larger than 65535 (16 bits)..
how to calculate time in seconds
there is no need for 2 TIMERs to do that... how exactly are you going to increment a TIMER with ... a TIMER INT? you just need a timer and some variable to do the counting of interrupts.
0x41 0x56 0x45!!
calculating time in 8051 interrupts
Hi!
in every timer0 interrupt, set the TH0 and TL0 to accurate frecuency and use a counter variable.
This variable is the auxiliar to use longer times than 16 bits
calculate timer count
Hi!
You can do this very accurately by using just one timer.
See the complete keil project that is attached. Study the code carefully.
Ask if still not clear about the code.
Regards.
