if we are using continuosly then there is some effectjustfun said:no
this is an unsubstantiated rumor
justfun said:no
melc said:justfun said:no
I suggest you a simple experiment.
Take an egg and separe the albumin. Mix the albumin and create a shape of about 0.5mm thick on a glass windows.
Use 2-4W EIRP at 900MHz and touch with the antenna the albumin.
See how much time do you need untill it will be baked near the antenna (it becomes white from transparent ).
The same with all your soft tissues (including the one beliving everything is rumor).
Electromagnetic effect is cumulative and more dangerous for childrens. Do you know why ?
