+ Post New Thread
Results 1 to 16 of 16
  1. #1
    Full Member level 5
    Points: 3,270, Level: 13
    Join Date
    Jun 2006
    Posts
    259
    Points
    3,270
    Level
    13
    brain cancer is not caused by mobile phones
    Does frequent use of
    mobile phone causes brain
    tumar ?
    •   Alt14th January 2008, 07:42
      advertising
  2. #2
    Full Member level 5
    Points: 3,089, Level: 13
    Join Date
    Jan 2006
    Posts
    287
    Points
    3,089
    Level
    13
    brain tumar
    no research has proved that it harms. u will get many e-mails saying its very harmful, but science has not proved it yet.
    Naveed
  3. #3
    Newbie level 3
    Points: 889, Level: 6
    Join Date
    Jan 2008
    Posts
    Points
    889
    Level
    frequent use of mobile phones
    no
    this is an unsubstantiated rumor
    1 members found this post helpful.
  4. #4
    Full Member level 3
    Points: 2,238, Level: 10
    Join Date
    Dec 2006
    Posts
    188
    Points
    2,238
    Level
    10
    are the mobile phones cause to gents
    Quote Originally Posted by justfun
    no
    if we are using continuosly then there is some effect
  5. #5
    Full Member level 3
    Points: 3,007, Level: 12
    Join Date
    Aug 2004
    Universal Citizen
    Posts
    161
    Points
    3,007
    Level
    12
    brain tumar
    Science does not prove it yet!!! Like smoking, not scientifically provet it causes all the deseases that it is responsible.
    Mobile works on with 800 to 1900 Mhz frequencies. The electromagnetic energy at these frequencies causes heatin of water base tissues. Hence the cells are affected the same way a microwave oven heats whatever you put inside.
    This does not mean that brain tumor is caused in a long run but it is possible to cause it or to help in developing it when there is predisposition.
    So, be cautious in order to misnimise any risk for this.
    Use the phone only when necessary.
    Regards
    P.
  6. #6
    Full Member level 6
    Points: 4,873, Level: 16
    Join Date
    Apr 2005
    Posts
    391
    Points
    4,873
    Level
    16
    does talking on a cell phone cause cancer
    no
    I suggest you a simple experiment.
    Take an egg and separe the albumin. Mix the albumin and create a shape of about 0.5mm thick on a glass windows.
    Use 2-4W EIRP at 900MHz and touch with the antenna the albumin.
    See how much time do you need untill it will be baked near the antenna (it becomes white from transparent ).
    The same with all your soft tissues (including the one beliving everything is rumor).
    Electromagnetic effect is cumulative and more dangerous for childrens. Do you know why ?
  7. #7
    Full Member level 6
    Points: 5,110, Level: 16
    Join Date
    Feb 2006
    Posts
    336
    Points
    5,110
    Level
    16
    mobile long time heats the brain
    yes it is dangerous but causing a tumor is not yet proved by experiments.
    •   Alt16th January 2008, 20:20
      advertising
  8. #8
    Member level 1
    Points: 1,218, Level: 7
    well-read's Avatar
    Join Date
    Jan 2008
    Posts
    34
    Points
    1,218
    Level
    7
    high risk caused by mobile phones
    Quote Originally Posted by melc
    no
    Yes, I agree. Please don not put it nearby your heart or head for a long time, especailly when you are sleeping!!
  9. #9
    Full Member level 1
    Points: 1,367, Level: 8
    raghuram_msc's Avatar
    Join Date
    Jul 2007
    Posts
    95
    Points
    1,367
    Level
    8
    mobile phone causes
    Hi All,
    I would like to add that i was once browsing into metacafe, where i found how an egg was "cooked" literally when the guy used to cell phones with the egg in between. Then I thoght it was a camera trick...but now i realise it is possible.
    Prolonged cell-phone users should use wired-headsets (not blue tooth again...!!). That will minimise the risk to some extent.
    Also, though out of topic, some people (mostly gents, for obvious reasons) put cell phone in their shirt pocket in vibration mode. This does cause severe risks on heart, b'cos of the chances of resonance that the heart might just pick-up from those vibrations.
    Sai
  10. #10
    Full Member level 1
    Join Date
    Jul 2007
    Posts
    95
    Points
    1,367
    Level
    8
    does talking on cell phone cause brian cancer
    Dear Friends,
    Below is the link that I was talking about,
    http://www.metacafe.com/watch/653198...h_your_mobile/
    Please let me know what you feel about this...!!
    Best Regards,
    Sai
  11. #11
    Full Member level 4
    Points: 2,273, Level: 11
    joe1986's Avatar
    Join Date
    Jan 2008
    Posts
    207
    Points
    2,273
    Level
    11
    empirical evidence of mobiles and brain damage
    THE PROLONGED use of CELL phones will REDUCE UR BRAIN CELLS RATHER than causing a BRAIN TUMER................IN ORDER TO PREVENT UR BRAIN CELLS from reducinG..................it is advisable THT u use earphones while TALKING ON THE CELL PHONE.................
  12. #12
    Advanced Member level 3
    Points: 7,502, Level: 20
    salma ali bakr's Avatar
    Join Date
    Jan 2006
    Posts
    971
    Points
    7,502
    Level
    20
    Re: Does frequent use of mobile phone causes brain tumar ?
    didn't you see the famous mail that circulates about the use of cell phones, where an egg was cooked between two mobiles :D
    i think it's the same one in the link given above...it heats up your head, that's the effect of the EM waves and that's what causes all the trouble !
  13. #13
    Member level 3
    Points: 1,670, Level: 9
    wolly's Avatar
    Join Date
    Mar 2006
    Posts
    58
    Points
    1,670
    Level
    9
    if a cellphone can boil an egg..
    .. what will happen to those living next to cellphone towers ...
    •   Alt26th January 2008, 19:58
      advertising
  14. #14
    Banned
    Points: 5,790, Level: 18
    Join Date
    Jun 2005
    scotland uk
    Posts
    646
    Points
    5,790
    Level
    18
    youve never watched mythbusters on discovery channel ???
    they proved mobile phones er 1000 of them in a pile with an egg in the center
    didnt even warm the shell {average phone is 5w input to a shaddy dipole }
    so 5kw erp + gain if any
    if this doesnt cook an egg im not surprised
    as the resonant frequency of the hydroxide molicule' covalent bonds is 2.349ghz and a phone operates at 800 -1000mhz
    brain tumors are like any form of cancer
    where the body looses count of the cells it has on the go
    becouse cancer Tcells fail to chemicaly signal there existstance to the brain
    the virus the cells have inhibbits the transmitter chemicals
    and also the cell fails to die becouse it never recieves a message to die from the brain or its nearest node it was spawned from this is yet unclear to science how exactly stem cells nodes on the skin play a role in how a cell behaves when its time for it to die
    so CELL PHONES HAVE VERY LITTLE TO DO WITH CANCER my pal
    infact its more probable to get this in the paper
    CELL PHONE SHRINK'S UNDISCOVERED BRAIN TUMOR'S AND SAVES LIFE's
    still there is the fact that there is atleast 1000 upperclass too well payed members of goverments labs etc
    who study such things rolling about laughting and counting the dosh the goverment payed them
    its scientific well accepted fact that there is over 50 types of cancer that are directly caused and known to be caused by viruses including some STD's
    so by a process of diductive reasoning its safer to assume that all cancers are caused by a virus entering or leaving groups of cells
    than it is speculate on the rf cause
    it is also a fact that 1-2hrs in the sun will expose you to a full lifetimes worth of RF at any frequency,... and as much as all the xrays taken that day world wide
  15. #15
    Full Member level 1
    Points: 2,589, Level: 11
    Achievements:
    7 years registered
    halls's Avatar
    Join Date
    Nov 2007
    Basque Country
    Posts
    111
    Points
    2,589
    Level
    11
    hi,
    as i can see every post refers to the same concept, which is matter overheating. I'll just give another point of view of this situation.
    As you can see in wikipedia (http://en.wikipedia.org/wiki/Cancer) cancer is caused by genetic abnormalities, which at the same time are caused by radiation, amongst others.
    To what radiated waves in nature concerns, these can be classified in two types (there are many other ways of classification): ionizing emissions and non-ionizing emissions. Ionizing emissions are capable of modifying the atomic structure of the matter, thus the non-ionizing are not. These emissions are radiated at REALLY HIGH frequencies, as high as ultraviolet radiation (about 1000000 GHz) and above (ultraviolet, x-rays, gamma rays).
    Frequency determines the level change in a signal, for what 1 Hz means 1 change (cycle) per second. When a chemical molecule suffers radiation, it changes its orientation according to the freq. When that freq is too high, the molecule change changes so fast it ends breaking its structure, and thus, modifying genetic structure (if its a genetic molecule).
    The point of all this text is, that what is important to look after regarding to harmful radiation is the frequency of operation. As mobile phones work at 800 MHz - 2 GHz range, its far enough from those 1 million GHz. Of course overheating could be a problem, but remember that a microwave oven runs at about 500-800 W, and a mobile phone just 1 - 5 W ;)
    Anyways, none of this is scientifically confirmed. I just wanted to give another point of view.
    I am not worried at all by the use of mobile phones myself.
  16. #16
    Banned
    Join Date
    Jun 2005
    scotland uk
    Posts
    646
    Points
    5,790
    Level
    18
    you forget to use the word CAN be caused by radiation
    or can be caused by virus that gets excited by radiation
    most cells are far to small to be anything more than moved around by rf
    possibly rupture and this causes repair mechanisms to trigger
    and yes your right genetic abnormalities are inherant in how strong a cell at repairing damage to its factory's
    the FACT remains cancer is more often triggered by a virus
    attacking the cell that isnt so strong or weekened by rf
    so we are both right
    however i dought phones will cause much more of an issue
    than 10 seconds a day spent in the sun and never use a phone
    ...:D
