tronix69
Newbie level 3
How does the ICD work with a PICKIT2? Do you need to load a bootloader to the PIC first? Is the data transfered via the ICSP header?
I was reading the supported device list and it says the 16F877 Supports ICD without the need for the header board and adaptor, Im used to the old style programmers which required ICD to be done via RS232.
I want to build a proto board using a 16F877 and PICKIT2 is there any thing other than ICSP that is needed?
Cheers
Cheers
