Question about elements impedance in dipole antenna design
jsp
Member level 3
i have some question about the dipole antenna design
suppose u have tx output 50ohm
and matching 50 to 300
at that point two lamda/4 line then what should be the imp of the elements of just for electrical length it should be quarter wave
thanks in advance
Re: dipole antenna design
Hi jsp,
r u talking abt a folded dipole?
Cheers,
Element7k
thanks in advance
I think he asks for the elements for "antenna matching unit".
If so:
There is no specific elements for the whole band of frequency.Divide the band into 5 or more and designate values.This is the way how it is done in HF.
yes it is about the folded dipole
pl give some tips
thank you
bandwidth
The SWR bandwidth of a folded dipole is less than a cylindrical dipole of the same spacing between wires. It is very difficult to make a dipole of 10% bandwidth of SWR under 3:1.
On the HF band frequency assignments for a station are in narrow ranges. They use dipoles in parallel, one resonant for each band.
The popularity of the folded dipole is that you can feed it with 300 ohm parallel wire line which has low loss. This is good for the VHF band.
Since transmitters and receivers of all types are designed for 50 or 75 ohm lines, it is best to use a feed line and antenna at those impedances.
