VHDL circuit for detecting 8 bit inputs changes
Mercury
Member level 3
Detecting 8 bit changes
Hello!
I would like to make a VHDL circuit ( xilinx 9500 cpld, webpack 5.2 ) that would set the IRQ output if any of the eight inputs ( Din: in std_logic_vector(7 downto 0); ) changes it state. The IRQ should be cleared at the rising edge of the STR input. The problem is that I cannot detech vector input changes and I cannot change states of one output from two processes.
George
Re: Detecting 8 bit changes
the problem is simple you can post your code so we can help.
I think the problem may be that you forget to put the inputs in your sensitivity list ; i said may be because i have faced this problem before and it was because of this reason
If the problem is due to the inclusion of the element in the sensitiviy list, Model sim will warn that the element should be included withtin the list.
