List of Microcontroller which i can fuse using PC??
agk.ganesh
Newbie level 5
Hi all :):)
I have little experience in working with AT89S8252 MUC for my mini Project... I fused my program into it using a very simple circuit and PC.
I need the list of Microcontrollers which r easy to fuse programs like the above 1.. with added functionality ...
I could not spend on Development Board :(
Thanks...
Waiting for replies... :)
Are you restricted to Atmel's microcontrollers? If not, there are a lot of microcontrollers that can be programmed by simple hardwares, and appropriate softwares. For example, I can program most of my PICs (Microchip's microcontrollers) with a JDM-compatible programmer, and softwares like WinPIC (from DL4YHF), WinPic800, or PICPgm (I've got about 80 different PICs).
Cheers,
    agk.ganesh
Cheers,
Not restricted to Atmel... But i have experience of working in that... :)
My project is abt transmitting the temprature sensed to PC through Bluetooth...
So wat wuld u recommend me to use for my project....
Thankss
blue tooth txd and rxd means more manipulation , so need mid/higher end mc
Still waiting for reply.... frnds!!
So can u tell the Mid end mc's which i can fuse program easily using my PC?
Thanskssss
Now days each and every microcontroller uses isp.
So you can programmer any mc atmel, pic renesas etc. with simple isp adoptor
select your micro according to your need and your interest.
Regards
Nandhu
    agk.ganesh
Can any1 give me a list of few mc which will suit me for my project better...
Waiting for reply.....
help me plssssss
There is a variety of µC. PICs (16f, 18f ..), AVR.,....
Chosing the appropriate one depend on your application.
Can you give as details about ?
Shall i know what your problem actually is?
Almost all microcontrollers in the world should be connected to the pc for programming, thro rs232, parallel port or usb.
unless you make clear what problem does you face, there will be no conclusion.
Make it clear.
Regards
Nandhu
