View Poll Results: which tool is monstly used for ent-to-end product
Voters
20. You may not vote on this poll
  • cadence
    9 45.00%
  • synopsys
    11 55.00%
+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Junior Member level 3
    Points: 1,159, Level: 7
    Join Date
    Jun 2007
    Posts
    30
    Points
    1,159
    Level
    7
    why we always apply trigger to flip flops
    hello guys ,
    why we need clock edge transtion ( either fall or rise ) for design of flip-flop
    •   Alt19th December 2007, 11:20
      advertising
  2. #2
    Full Member level 5
    Points: 3,046, Level: 12
    lordsathish's Avatar
    Join Date
    Feb 2006
    Asia
    Posts
    247
    Points
    3,046
    Level
    12
    triggering of flip flop
    sequential circuits need to synchronous... sine async ckt's have quite a number of problems like rece conditions sync ckts are preffered over them... for this synchronous operation edge-triggering is used...
    1 members found this post helpful.
  3. #3
    Full Member level 5
    Points: 2,707, Level: 12
    Join Date
    Mar 2007
    Posts
    305
    Points
    2,707
    Level
    12
    triggering of flip-flop
    this is the basic difference between a flip flop and a latch.
    latches are level sensitive and flip flops are edge sensitive.
    This makes the contents to be stable for entire clock pulse in flip flops
    Corect me if i am wrong
  4. #4
    Member level 1
    Points: 1,499, Level: 8
    Join Date
    Mar 2006
    Posts
    36
    Points
    1,499
    Level
    8
    triggering of flip-flops
    synchronous at the same time ,all the flip-flop will be triged
    •   Alt20th December 2007, 05:26
      advertising
  5. #5
    Newbie level 1
    Points: 898, Level: 6
    Join Date
    Dec 2007
    Posts
    Points
    898
    Level
    why we need clocks?
    hi,l have used cadence tool,but used synopsys. l will try
  6. #6
    Member level 1
    Points: 2,231, Level: 10
    Achievements:
    7 years registered
    Join Date
    Aug 2007
    Chennai
    Posts
    41
    Points
    2,231
    Level
    10
    whats the need of clock pulse in flip-flop
    If we are not using the edges, whenever the input value changes output also change accrdingly. Because of this we will get erroneous values before settling in actual value. It will make unnecessary switching and power loss. So we are narrowing the sampling window and allowing the input stable. That's why we are using edges.
    Regards,
    Kanags
  7. #7
    Newbie level 3
    Points: 1,157, Level: 7
    Join Date
    Aug 2006
    Posts
    Points
    1,157
    Level
    7
    triggering flip flop
    First we need some cell to keep data. That means we need more than combinabtion logic.
    I think use edge maybe the only way to capture data, even for latch.
  8. #8
    Member level 4
    Points: 1,400, Level: 8
    Join Date
    Aug 2007
    Posts
    71
    Points
    1,400
    Level
    8
    triggering of of flipflop
    Dear dude,
    To store data we must edge trigger, either on positive edge or neative.
    so only it will be understandable what data has to stored during that particular edge. mainly to synchronous data and clock to get data stored
    if it level senstive it just passes the data from i/p to o/p till it reamins high.
    Santu
  9. #9
    Full Member level 3
    Points: 3,343, Level: 13
    Join Date
    Dec 2004
    Posts
    154
    Points
    3,343
    Level
    13
    why we need clocks
    If we don't use DFF to latch data, we can't know the data process time.
    In out application, we always do some math calculation or timing control.
    If we don't use timing aspect in our design, it is always problem to real result.
    •   Alt2nd January 2008, 11:53
      advertising
  10. #10
    Newbie level 2
    Points: 907, Level: 6
    Join Date
    Dec 2007
    Posts
    Points
    907
    Level
    why we need clock
    We need it b'coz otherwise it will act as an latch
    We have to consider even the setup time also
