extended gerber composite to layer free tool
reiniheini
Member level 1
extended gerber
Hi everyone
i´m still looking for a programm that converts a composite layer to a single layer which contains all the Information. ie. open drillholes
Plz let me know if there is such a tool
Regards reinheini
how to open the physical layers on gc-prevue?
Can you explain a bit more about what you are wanting to do please?
In GC-Prevue you can view a layer as composite and simply turn it into a negative or positive layer.
However, the program that generates the layers in the first place may be what you need to use.
gerber composite layer merge
what I exactly need is a programm that converts a composite layer in a single physical layer. That means a simple extended gerber layer which contains all the information from the composite layer.
I'd like to plot this layer on a photo plotter with open drill holes
But the photo plotter only works with single layers and not with composite layers
Thanks in advance
reiniheini
gcprevue composite
Hmm, as mentioned above, gc-prevue.
Turn the layer to nbe positive instead of composite.
You can them merge this with another positive layer by copying them both to a new layer.
