Changing code with 9600 baud rate to 4800
Livingston
Full Member level 2
Chennai-India
Regarding Baud rate
The code shown below which is of 9600 baud rate i want to change for 4800
Please guide me
Serial.c
#include <REG52.H> /* special function register declarations */
/* for the intended 8051 derivative */
#include <stdio.h> /* prototype declarations for I/O functions */
#ifdef MONITOR51 /* Debugging with Monitor-51 needs */
char code reserve [3] _at_ 0x23; /* space for serial interrupt if */
#endif /* Stop Exection with Serial Intr. */
/* is enabled */
The delay function
void Delay (const unsigned int DELAY)
unsigned int x, y;
for (x = 0; x <= DELAY; x++)
for (y = 0; y <= 120; y++);
The main C function. Program execution starts
here after stack initialization.
void main (void) {
Setup the serial port for 9600 baud at 11.0952 MHz.
#ifndef MONITOR51
SCON = 0x42; /* SCON: mode 1, 8-bit UART, enable rcvr */
TMOD |= 0x20; /* TMOD: timer 1, mode 2, 8-bit reload */
TH1 = 0xFD; /* TH1: reload value for 9600 baud @ 11.0592 MHz */
TR1 = 1; /* TR1: timer 1 run */
TI = 1; /* TI: set TI to send first char of UART */
#endif
Note that an embedded program never exits (because
there is no operating system to return to). It
must loop and execute forever.
while (1)
P1 ^= 0x01; /* Toggle P1.0 each time we print */
Delay(2000);
printf ("Gprmc, utc, date, Time, Lat, Long, Speed"); /*Print "Character Data" */
Re: Regarding Baud rate
Change the TH1 reload value from FDh to FAh ..
Regards,
IanP
        Some typical baud rates for an 11.0592 crystal:
           Baud rate  SMOD   TH1
             19200      1   0FDH
              9600      0   0FDH
              4800      0   0FAH
              2400      0   0F4H
              1200      0   0E8H
               300      0   0A0H
Please can you explain me how to calculate the bard rate Is there is any formula?
This info (including formulas) is readily available on the web ..
For example, here:
"Setting the Serial Port Baud Rate"
Regards,
IanP
Can you help me how to write a program to receive and to transmit the data in uart of 89c52, 4800 baud rate
Please
You need tree functions:
void initBaudRate(void)
TH1 = 0xFA; /* TH1: reload value for 4800 baud @ 11.0592 MHz */
unsigned char uartSend(unsigned char uc)
while(TI==0)
; /* wait until transmiter empty */
TI = 0;
SBUF = uc; /* send char */
return uc;
unsigned char uartGet(void)
unsigned char uc;
while(RI==0)
; /* wait for char */
uc =SBUF; /* read the received char */
RI = 0;
return uc;
Added after 19 minutes:
The formulas for baudrate in modes 1 and 3 are:
BaudRate = (1+SMOD)•(fXTAL/ 12 ) / (32•(256-TH1)) = (1+SMOD)•(fXTAL/ 384) / (256-TH1)
TH1 = 256 – (1+SMOD)•(fXTAL/ 384) / BaudRate
TH1 = 256 – (fXTAL/ 384) / BaudRate if SMOD = 0
TH1 = 256 – (fXTAL/ 192) / BaudRate if SMOD = 1
You can use a better initBaudRate function:
void initBaudRate(unsigned baudrate)
PCON |= 0x80; /* SMOD = 1 */
TH1 = (unsigned char)(256 – ((fXTAL/ 384) / BaudRate))
    Livingston
hey i dont know about c but in assembly you just change the value in scon
