hello my dear friends
in my project i need to have muliply and dividing 32 bit floating point.but i have ic that can muliply and dividing in fixed point. i need an algorithm that does it.
thank you.
You can divide the floating nuber into 2 parts, the exponent and the magnitude. For the magnitude, you can use the multiply and divide instructions as for integer and fixed points. For the exponent, you can use the add and subtract instructions (as integers).
with language r u using if it is or basic then all of these high level compilers supports floating point calculation .........in case of assembly check math tutorial in www.8052.com i think it will help.
thanks for your guidance .
i need more goid. i dont notice your mean. supose that x and y are 32 bit fixed point register and i want to have floating multiply z=x*y.
