+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Newbie level 3
    Points: 939, Level: 6
    Join Date
    Oct 2007
    Posts
    Points
    939
    Level
    canbus canh canl
    Hello!
    I want to connect two High Speed CAN transceivers (MCP2551) but I donít know exactly how to do it. Is it enough to link the CANH and CANL pins of the transceivers or do I have to link also the grounds? What connector is the most suitable? Is a DB9 ok? Do I have to terminate the bus with a termination resistor at both ends of the bus in order to avoid reflections? Or are those resistors included in the transceiver? (I read the transceiverís datasheet and they donít mention those resistors).
    Thanks a lot in advance for your help!
    •   Alt5th December 2007, 18:56
      advertising
  2. #2
    Advanced Member level 5
    Points: 16,636, Level: 31
    Join Date
    Jul 2001
    Oberon
    Posts
    1,897
    Points
    16,636
    Level
    31
    canl can low canh
    CAN uses a DB9 as standard.
    Here are the pinouts.
    9 Pin (male) D-Sub CANbus PinOut Pin # Signal Names Signal Description
    1 Reserved Upgrade Path
    2 CAN_L Dominant Low
    3 CAN_GND Ground
    4 Reserved Upgrade Path
    5 CAN_SHLD Shield, Optional
    6 GND Ground, Optional
    7 CAN_H Dominant High
    8 Reserved Upgrade Path
    9 CAN_V+ Power, Optional
    You dont have to connect the grounds, just can high and can low.
    Each end of the bus must be terminated with a 120R resistor.
    They are not in the tranceiver as the tranceiver might not be at the end of the bus.
  3. #3
    Newbie level 3
    Join Date
    Oct 2007
    Posts
    Points
    939
    Level
    can bus shielding
    Thank you so much btbass! You told me everything I needed to know!
  4. #4
    Full Member level 4
    Points: 2,803, Level: 12
    Join Date
    Feb 2002
    Posts
    211
    Points
    2,803
    Level
    12
    db9 can bus pinout
    If the two equipment have power supply you can connect only CANH and CANL.
    •   Alt20th December 2007, 12:36
      advertising
  5. #5
    Banned
    Points: 22,963, Level: 36
    Join Date
    May 2007
    USA & Canada
    Posts
    437
    Points
    22,963
    Level
    36
    can bus canh
    It depends on which protocol you are going to use, some protocol has a definition of connectors.
  6. #6
    Advanced Member level 2
    Points: 9,335, Level: 23
    Davood Amerion's Avatar
    Join Date
    Mar 2005
    Persia
    Posts
    584
    Points
    9,335
    Level
    23
    can bus shield termination
    If 2 system using one ground, it is not needed to connect ground, otherwise you should connect ground signal.
  7. #7
    Banned
    Join Date
    May 2007
    USA & Canada
    Posts
    437
    Points
    22,963
    Level
    36
    canh canl
    can is differential signal net, no ground required.
    A gnd shield will help for emi purpose.
  8. #8
    Join Date
    Mar 2005
    Persia
    Posts
    584
    Points
    9,335
    Level
    23
    can canh canl
    Quote Originally Posted by funnynypd
    If two node are galvanically isolated , it may no problem.
    Otherwise differential ground voltage on 2 node must limited. so it is better to cannect ground signal.
    •   Alt21st December 2007, 16:45
      advertising
  9. #9
    Banned
    Join Date
    May 2007
    USA & Canada
    Posts
    437
    Points
    22,963
    Level
    36
    how to connect can bus
    true,
    For vehicle has the same ground, a two wire network will also work.
