Help me to generate C code from matlab.
hbaocr
Full Member level 4
Hochiminh City university of technology (VietNam)
matlab generate c code
Hello,all
I'm a final year student . And I have some problem in my project.
That is how can I generate C code from matlab code to use It in my Keil ARM project!
I'm analysing Spectrum of Voice signal using my PC by matlab.I my problem is : how can i generate it to C code or header file *.h and use this code to write my program in KEIL ARM to let my uC LPC 2148 recognize Voice to control other devices .That Make my project can operate without depending on PC.
generate c++ code from matlab
did you chek mex?
try it and you can obtain good results.
generating c code from matlab
check out this paper...
here is the link...
simply copy n paste C code in keil IDE....
:D:D:D
how to create c code from matlab
hi hbaocr ,
could you share some more info.
Have u used Real Time Workshop with embeded c-coder for the above.
matlab c
Look at the new Embedded MATLAB. It is extremely simple and works seamlessly with Real-time wrokshop to generate C/C++ code from M-Files and Simulink Models. I think you will find it in MATLAB R2007a and later.
There are also thrid-party tools that take M-Files and generate C Code such as Catalytic MCS and ACCelDSP.
See this:
I hope this helps.
Good luck.
catalytic mcs open source
Does anybody follow up on this topic? I read the embedded site, but it seems commercial product. Do we have any freeware or open source?
generate c code matlab
It is possible to generate directly from Matlab using mex function. But the generated code usually looks weird and not easy to follow. Just code your own program in C and only call the specific Matlab functions from Visual Studio. You will get an independent executable code.
matlab generate c++
i will tell u tomorrow
