POE (Power over Ethernet) Ethernet to RS232/485 Converters
serial_RJ45
Junior Member level 1
USA
Has anyone tried making a Ethernet to serial converter that is POE compliant?
Would it be nice to have a Ethernet device server that can be installed in-line between the Ethernet Switch and the PLC serial port without need for power supplies.
If this converter is small enough, it could be used like an in-line coupler.
all have tiny embbeded components that make this possible.
Re: POE (Power over Ethernet) Ethernet to RS232/485 Converte
Just curious, did u find such a module?
PoE + Ethernet to serial interface.
Thanks
