+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Member level 4
    Points: 2,281, Level: 11
    Achievements:
    7 years registered
    Join Date
    Jul 2006
    Malaysia
    Posts
    72
    Points
    2,281
    Level
    11
    convert basic to asm
    is there any software to convert BASIC language to ASM language?
    or BASIC to C language..
    •   Alt22nd November 2007, 12:39
      advertising
  2. #2
    Member level 5
    Points: 2,366, Level: 11
    Join Date
    Mar 2007
    Posts
    87
    Points
    2,366
    Level
    11
    convert basic to assembler
    no, i think there is no software like that... but u can translate it in to other languages by ur self, if u know both of them
  3. #3
    Junior Member level 2
    Points: 1,718, Level: 9
    Achievements:
    7 years registered
    binu_ji's Avatar
    Join Date
    Oct 2006
    Posts
    23
    Points
    1,718
    Level
    9
    basic to asm translator
    Use Basic Compiler to get the HEX code and from the HEX code you can get the assembly code by using Disassembler.
    Although you can get the LIST file which is in assembly code from the basic compiler output.
    •   Alt24th November 2007, 06:43
      advertising
  4. #4
    Member level 4
    Achievements:
    7 years registered
    Join Date
    Jul 2006
    Malaysia
    Posts
    72
    Points
    2,281
    Level
    11
    converting basic langugage code
    thanx binu_ji,can anyone suggest any software or website for disassembler.. i'm newbie in assembly for PIC..
    Added after 11 minutes:
    yatta! i has try PIC simulator IDE to disassamble hex,no i can compare between BASIC and ASM :D
    PIC Simulator IDE - http://www.oshonsoft.com/pic.html
    An application that supplies PIC developers with graphical environment for Windows and integrated BASIC compiler, assembler, simulator (emulator), disassembler, and debugger.
    DIS16 - http://fly.cc.fer.hr/~arsen/dis16/
    PIC16C5x micro-controller family disassembler, by Arsen Torbarina. [Commercial]
    micros/pic - http://margo.student.utwente.nl/el/micros/pic/
    Contains several PIC disassemblers.
    ABC MICRO - http://www.abc-micro.co.yu/
    PICabc-visual assembler, disassembler and PIC tutorial provide simple method for programming PIC microcontrollers. [Commercial]
    MacPIC - http://www.macrobotics.com/MacPIC.html
    PIC Development System for Macintosh includes PIC disassembler, by MacRobotics. [Shareware]
    DJDASM - http://www.geocities.com/dinceraydin...sm/djdasm.html
    Disassembler for the 16F84 PIC micro implemented in JavaScript. It has colorized HTML output.
    Joe's Cat PicDis - http://www.joescat.com/micro/picchip.htm
    A HEX file utility and disassembler for over 125 variations of PIC chips. [Free and commercial versions]
    Angelica - http://online.dip.jp/angelica/index_e.html
    Disassembler for SX chips.
    Mikado - http://online.dip.jp/mikado/index_e.html
    A disassembler for pic. Also it can make flowcharts, and output of MPASM or CVASM style. [Freeware]
    GNUPic Disassembler - http://www.gnupic.dds.nl/disassemblers.html
    PIC disassemblers and some more disassemblers.
    Added after 1 minutes:
    *now
    •   Alt24th November 2007, 10:14
      advertising
  5. #5
    Advanced Member level 5
    Points: 16,636, Level: 31
    Join Date
    Jul 2001
    Oberon
    Posts
    1,897
    Points
    16,636
    Level
    31
    micro basic language
    If you are using Mplab, just build your project and then select 'View', 'Disassembly Listing'.
  6. #6
    Advanced Member level 1
    Points: 4,132, Level: 15
    Join Date
    May 2006
    Posts
    414
    Points
    4,132
    Level
    15
    cvasm assembly code
    i gues proton can do this
  7. #7
    Newbie level 6
    Points: 4,107, Level: 15
    ennio's Avatar
    Join Date
    Sep 2006
    La Paz, Bolivia
    Posts
    13
    Points
    4,107
    Level
    15
    pic18 disambler
    mikroBasic to ASM translator
    http://www.micro-examples.com/public...ranslator.html
    hope it´s useful...
    Regards
    ennio
  8. #8
    Newbie level 2
    Points: 877, Level: 6
    Join Date
    Jan 2008
    Posts
    Points
    877
    Level
    mplab disambler
    up
  9. #9
    Member level 4
    Achievements:
    7 years registered
    Join Date
    Jul 2006
    Malaysia
    Posts
    72
    Points
    2,281
    Level
    11
    pic16c5x disassembler
    i think i got the solution,in mikroC has library asm(),and i has start learning mikroC ;)
    Added after 3 minutes:
    so i can use asm in C.and C also can dissamble to asm.same with basic..
    •   Alt22nd January 2008, 14:09
      advertising
  10. #10
    Full Member level 5
    Points: 3,940, Level: 14
    Join Date
    Feb 2003
    Pakistan
    Posts
    260
    Points
    3,940
    Level
    14
    converting basic to asm
    I also need disambler file from hex to asm, once I had it but lost it now plz if any one has it upload.
