+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Full Member level 1
    Points: 2,260, Level: 11
    Achievements:
    7 years registered
    Join Date
    Feb 2007
    from the deepest roots of KAMOTE land
    Posts
    111
    Points
    2,260
    Level
    11
    import DXF file into Expedition
    i have a .dwg drawing which i intend to use in my layout job so i had to save it as a DXF file in AutoCAD 2007. i had to Import that DXF file into my layout job in Expedition, and i did successfully.
    the only problem is that the imported DXF file seems to be way too small from its dimensions in the original DWG and DXF file in AutoCAD. the imported DXF drawing is even smaller than my smallest drill size.
    any advice on how to do it right so i could have the correct drawing dimensions for my imported DXF file? is there a setting for AutoCAD and Expedition for this?
    •   Alt21st November 2007, 23:37
      advertising
  2. #2
    Full Member level 4
    Points: 3,667, Level: 14
    Achievements:
    7 years registered
    senilicus's Avatar
    Join Date
    Feb 2007
    Amsterdam / The Netherlands
    Posts
    230
    Points
    3,667
    Level
    14
    Re: import DXF file into Expedition
    Make sure the units of your DXF are the same as the units in Expedition.
    1 members found this post helpful.
    •   Alt22nd November 2007, 12:36
      advertising
  3. #3
    Full Member level 1
    Achievements:
    7 years registered
    Join Date
    Feb 2007
    Posts
    111
    Points
    2,260
    Level
    11
    it worked just as i thought.
    i have overlooked the units i used in Expedition.
    Added after 2 minutes:
    thanks a lot..
    •   Alt22nd November 2007, 23:37
      advertising
  4. #4
    Banned
    Points: 22,963, Level: 36
    Join Date
    May 2007
    USA & Canada
    Posts
    437
    Points
    22,963
    Level
    36
    same thing happened on the PADs layout.
    I never get a chance to use the Expedition, how good is it?
  5. #5
    Member level 4
    Points: 3,047, Level: 12
    Romanp's Avatar
    Join Date
    Dec 2002
    Posts
    74
    Points
    3,047
    Level
    12
    Hi, How to convert user layer to board outline?
    •   Alt25th December 2007, 23:23
      advertising
  6. #6
    Full Member level 5
    Points: 3,923, Level: 14
    Join Date
    Jun 2004
    India
    Posts
    272
    Points
    3,923
    Level
    14
    If anyone of you have tutorails for expedition kindly upload it.
    i am new to this tool and need to understand the design flow i have used pads earlier.
    thanks
