Circuit for measuring the current and voltage accros diode
saas123qa
Member level 2
I wnat to design an analog circuit to give a reading about the voltage and current a cross the diode , can any one help me?
Re: Circuit for measuring the current and voltage accros dio
off chip or on chip?
what do you mean by on/off chip
do you need to embed that circuit in the circuit you want to measure, or will it be an external measuring circuit?
would u like to see analog reading or digital?
Added after 3 minutes:
if u want analog measurement then use galvnometer in series with resistor and diode.. but if digitl then use sample and hold adc and seven sement decoder and display
