How can the Kvco affects the performance of PLL?
jasonxilion
Junior Member level 1
hi all:
how can the Kvco effects the performance of pll? can the Kvco be very large like 2Ghz/v?
if i want to design a vco with frequency range from 250M to 1.7Ghz and the supply voltage is only 1.8v, the Kvco is inevitably large.
then how can i do ?
thx
Re: Kvco is too large?
jasonxilion said:
hi all:
then how can i do ?
thx
hard to achieve this range, I think. But, why do you need this wide dynamic range?
hard to realize it?
i want to make a pll as a clock frequency multiplier for HDMI1.3
the data clock is 25M to 340Mhz, and the pll is used to 5 times the clock frequency
so how can i do it
thx
jasonxilion said:
hi all:
then how can i do ?
thx
almost everything is possible... but not always what you want!
Very large Kvco will be bad for phase noise and stability of the loop.
Assuming you have a LC tank you should use banks of switchable capacitors like most people do... And leave only a fraction of the total capacitance variation to a varactor.
Search for wideband VCOs in google, you'll find several papers and thesis on it.
thanks for your advice^_^
Kvco is too large?
i have seen Ic's from big companies , when the PLL will be used in very wideband , they make a bank of vco's and everyone cover some part and they do a some logic to select which VCO will be used , so they will not affect the stability or phase noise , they pay a chip area
everything is a compromise
khouly
i see,thank you all, budies
to khouly:
i have read some of your posters, you are really a expert^_^
Kvco is too large?
Kvco is dependent on the requirement and the max achieveable range of variosions in the capacitance you can achieve with the applied voltage . again the linearity play a major roll as the cap variation is not linear also the variation of L is not possible . so take the factors in consideration .
with regars
Kvco affects out-of-band phase noise, fn, loop bandwidth, phase margin & spur gain
jasonxilion said:
hi all:
then how can i do ?
thx
I think you can divied it to lots of bands. and each band Kvco is reduced.
