DC motor rpm control using pic16f84A !!code needed
thecall
Junior Member level 2
anyone plz give me the code for the DC motor control using pic16f84a plz upload the code and circuit diagram plz hellppppppp
Don't use the ancient 16F84, a 16F628 is a modern replacement and has a hardware PWM module making simple motor speed control trivial.
pic16f88 is the best .it better than both
Just visit Microchip and have at look at application notes. There are loads of stuff on motor control!
Here is a project I am working on. I can give you the schematic and HEX file, for code I can help you to write your own :wink:
anyone plz upload the complete project .............its going to be a great favour for me
Sounds like schoolwork.
The 16F84 is poorly suited to motor control, use a PIC with PWM instead.
PS nobody is doing you a favour by doing your homework for you.
PS Please make a search before posting, I've seen and even posted the entire details of what you're demanding quite earlier...just search out and you'll find it...
Best regards
