Errors in dual clock counter code in VHDL
anoop12
Member level 5
Hi all,
I need vhdl code for counter 74192( dual clock synchronous ).
I have written the code as below.
When I simulate it for upcounting or downcounting individually i.e. with only one process at a time, it works fine. But with two processes at a time it gives no output .
can anyone correct it?
here is the code
-- TI_UD_192.vhd
-- IC 74192 Decade Counter
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
entity DECADE_COUNTER is
port ( I_P: in std_logic_vector(3 downto 0); -- input
I_UP:in std_logic; -- up-counting clock
I_DOWN: in std_logic; -- down-counting clock
I_CLR: in std_logic; -- Asynchronous Clear
I_load_N:in std_logic; --load to BCD 7,active low(Preset)
O_Q: out std_logic_vector(3 downto 0); -- output
O_B_N: out std_logic; - down counting borrow pulse
O_C_N: out std_logic); - up counting carry pulse
end DECADE_COUNTER;
architecture BEHAV of DECADE_COUNTER is
signal COUNT:std_logic_vector(3 downto 0);
begin
-- process for up counting
process(I_UP,I_CLR)
begin
if (I_CLR='1') then count<="0000";
elsif ( I_UP'event and I_UP='1') then
if(I_LOAD_N='0') then count<=I_P;
else count<=count + 1;
end if;
if (count="1001") then count<="0000";
end if;
end if;
end process;
O_C_N<='0' when count="1001" else'1';
--process for down counting
process(I_DOWN,I_CLR)
begin
elsif ( I_DOWN'event and I_DOWN='1') then
count<=count-1;
end if;
if (count="0000") then count<="1001";
end if;
end if;
end process;
O_B_N<='0' when count="0000" else'1';
O_Q<= count ;
end BEHAV;
dual clock counter
Hey man !!! I am not that familiar with VHDL
but
I tell u one thing ..... Dont use one variable or signal as a target in two processes
U better count up and down in a sigle processs using IF ELSE Structure
Hope that Helps U !!!!!!!
If so DO GET ME few Points on this forum !!!
I have begun to study VHDL may be I can answer u better a feww days later
dual clock counter
You can't use 2 process since they assign a value for the same variable "count".
This is permitted in VHDL:
A process can assign value to Var1, Var2, ...VarN
but:
process1 and Process2 can't assign value to Var1, that's wha you did.
Re: dual clock counter
hi,
you can try that
add internal node
signal up_down_clk:std_logic;
signal up_down_flag:std_logic;
then
up_down_clk<=I_UP AND I_DOWN;
up_down_flag<=...............................
process(up_down_clk,I_CLR,I_LOAD_N,up_down_flag)
begin
if (I_CLR='1') then
count<="0000";
elsif(I_LOAD_N='0') then
count<=I_P;
elsif(up_down_clk'event and up_down_clk='1') then
if(up_down_flag='1') then
if(count="1001") then
count<="0000";
else
count<=count+1;
end if;
else
end if;
end if;
end process;
hello addn,
thanks for that wonderful suggestion.
Will you please clarify how to get that iflag signal that you have taken in your code.
regards
dual clock counter
hi,
about the flag
you need two negative edge D-FF with asynchronous reset
D-FF1:D<->'1',CLK<->I_UP,/RESET<->I_DOWN
D-FF2:D<->'1',CLK<->I_DOWN,/RESET<->I_UP
and then
up_down_flag<=Q1 AND NOT Q2;
