+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Member level 4
    Points: 2,351, Level: 11
    Join Date
    Jul 2007
    Posts
    75
    Points
    2,351
    Level
    11
    Why some NIMH battery packs got three wires.
    hi,
    i got a NiMH rechargeable battery pack from local market. well knows a cordless phone battery pack.the product Model is HGB-15AAx3 an it says "Ni-MH battery 3.6v 1500mah" & it's a green colored battery pack consisting 3 outputs wires.black ,red an white wire.
    My question is why there are 3 wires out puts of the battery pack?
    i measure the voltages of the battery pack and i noticed that only black and red wire gives the reading. The white wire give no any output.
    Thanks!
    •   Alt17th October 2007, 18:33
      advertising
  2. #2
    Advanced Member level 5
    Points: 12,565, Level: 26
    Borber's Avatar
    Join Date
    Jan 2000
    on third flor
    Posts
    1,602
    Points
    12,565
    Level
    26
    Re: Why some NIMH battery packs got three wires.
    White wire is thermistor terminal which is needed for battery temperature sensing during fast charging.
    You should measure white wire voltage against black and red. White wire have some voltage against one of other two wires if a thermistor for temperature sensing is build in.
    1 members found this post helpful.
  3. #3
    Member level 4
    Join Date
    Jul 2007
    Posts
    75
    Points
    2,351
    Level
    11
    Thanks borber.
    so if need to build a charger for this pack how could i use the temperature sensor.
    Do u have any idea what is the type of the sensor on the battry.
    Anlog -->variation in resistance
    --->variation of voltage
    or
    Digital-->SMB bus type temp sensors
    Thanks!
  4. #4
    Borber's Avatar
    Join Date
    Jan 2000
    on third flor
    Posts
    1,602
    Points
    12,565
    Level
    26
    It should be usual thermistor and cold resistance can be from 10k to 50k. Simply measure resistance between white and the wire that has no voltage against it to be shure.
    •   Alt18th October 2007, 06:07
      advertising
  5. #5
    Points: 14,157, Level: 28
    Join Date
    Jun 2005
    Stanford, SF Bay Peninsula, California, Earth, Solar System, Milky Way
    Posts
    1,418
    Points
    14,157
    Level
    28
    It's probably a thermistor.
    It could also be a 1-wire fuel gauge. But it's unlikely that a Ni-MH battery pack like yours would have a built-in fuel gauge.
  6. #6
    Member level 4
    Join Date
    Jul 2007
    Posts
    75
    Points
    2,351
    Level
    11
    Thank u very much for all your help.
    I am wondering whether i could make a Fast Charging circuit to charge
    this NIMH pack!
    Any Ideas! Circuits! Application Notes!
    Thanks[/b]
  7. #7
    Join Date
    Jun 2005
    Posts
    1,418
    Points
    14,157
    Level
    28
    Dilan,
    I'm not an expert on high-performance battery charging, but here a lecture note type material for charging Ni batteries http://www.batteryuniversity.com/partone-11.htm The rest of that web site is very informative as well.
    - Nick
  8. #8
    Advanced Member level 3
    Points: 7,585, Level: 20
    Join Date
    Dec 2004
    Posts
    759
    Points
    7,585
    Level
    20
    Well, that third wire is for temperature monitoring ...once the battery is almost or fully charged there is steep change in temperature curve, which is read my charging controller to stop any further charging.
    Sensor so used is basically reverse biased diode or thermistor followed by current limiting resistor.
    •   Alt21st October 2007, 07:27
      advertising
  9. #9
    Full Member level 4
    Points: 3,366, Level: 13
    Join Date
    Nov 2001
    Posts
    239
    Points
    3,366
    Level
    13
    A lot will depend on the quolity of the nicad pack but i have striped a battery pack down from a battery powered drill and the thired connection went to a heat swich that opened if the charger battery was to hot
  10. #10
    Member level 4
    Join Date
    Jul 2007
    Posts
    75
    Points
    2,351
    Level
    11
    Thanks every one for support this thread.following is measurements i get from the battery pack.
    Normal resistance between Negative and Thermostat 40.4k
    when after charging and gets heated the resistance is about 15k
    i will add a temp vs time when charging .Very soon
    again thanks for the support.
    Rgds
    dilan
