+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Member level 5
    Points: 1,666, Level: 9
    Join Date
    Aug 2007
    Posts
    90
    Points
    1,666
    Level
    9
    What are standard cell tracks ?
    hi,
    wat are tracks in std cells?
    what is meant my 9track,12track std cell?
    wat is d diff bt the above 2?
    which one is advantageous?
  2. #2
    Points: 945, Level: 6
    Join Date
    Oct 2007
    Posts
    Points
    945
    Level
    12 track standard cell
    tracks mean routing resources
    1 members found this post helpful.
    •   Alt16th October 2007, 03:48
      advertising
  3. #3
    Full Member level 1
    Points: 1,923, Level: 10
    Achievements:
    7 years registered
    Join Date
    Jul 2006
    Posts
    100
    Points
    1,923
    Level
    10
    standard cell 9 track
    track is the path in which wires can pass through
    •   Alt16th October 2007, 23:23
      advertising
  4. #4
    Full Member level 1
    Points: 3,440, Level: 13
    Join Date
    Jul 2002
    Posts
    100
    Points
    3,440
    Level
    13
    routing tracks 12 track 9 track asic
    How many tracks means how big your cell is. normally, 8 lambda is one track if I am right. It depends on the technology.
    •   Alt17th October 2007, 05:39
      advertising
  5. #5
    Full Member level 1
    Points: 2,844, Level: 12
    Join Date
    Aug 2005
    India
    Posts
    114
    Points
    2,844
    Level
    12
    what is 9-track standard cell library
    one track is approximately the minimum spacing between metal1 and metal1 via in a technology node . Track is generally used as a unit to define the height of the std cell. a 12 track cell will be taller than a 9 track cell. a 12 track std cell will be taller , that means more metal1 routing space is available within the cell, hence cells will be faster. where as in a 9 track cell, the cell will be compact, but speed is less compared to 12 track.
    9track -> less area, less speed compared to 12 track
    12tarck -> more area, more speed compared to 9 trac
    Regards
    Nav
    10 members found this post helpful.
  6. #6
    Member level 5
    Join Date
    Aug 2007
    Posts
    90
    Points
    1,666
    Level
    9
    track in standard cell library
    hi can u eloborate on the relation between more metal 1 routing space availability and speed of the standard cell......................
  7. #7
    Newbie level 3
    Points: 971, Level: 7
    Join Date
    Sep 2007
    Posts
    Points
    971
    Level
    7
    9/12 track standard cells
    Suppose you have a NAND gate. Now with same W/Ls of transitor if you make layout in 9 tracks and 12 tracks, then 12 track NAND gate layout would be somewhat in thinner but taller by 33.33%. Since it is taller that means there is more space horizontally available for routing over this 12 track cell compared to 9 track cell.
    Parikshit
    •   Alt18th October 2007, 16:55
      advertising
  8. #8
    Full Member level 1
    Join Date
    Aug 2005
    India
    Posts
    114
    Points
    2,844
    Level
    12
    standard cell and track
    hi praneshcn,
    the basic funda is simple , bigger cells has better driving capablity , than their equivalent normal cells . i.e they will be faster than their normal counter parts
    Regards
    Nav
  9. #9
    Advanced Member level 3
    Points: 4,851, Level: 16
    ivlsi's Avatar
    Join Date
    Feb 2012
    Posts
    864
    Points
    4,851
    Level
    16
    Re: What are standard cell tracks ?
    What is "via"?
