+ Post New Thread
Results 1 to 12 of 12
  1. #1
    Points: 8,778, Level: 22
    Join Date
    May 2002
    Posts
    1,184
    Points
    8,778
    Level
    22
    pre emphasis circuit
    what is Pre-emphasis and DE-emphasis circuits in FM voice radio?
    what is do?
    Please send information.
  2. #2
    •   Alt25th September 2007, 18:15
      advertising
  3. #3
    Points: 9,828, Level: 23
    Achievements:
    7 years registered
    Join Date
    Feb 2007
    All over the Map.
    Posts
    1,075
    Points
    9,828
    Level
    23
    pre-emphasis
    Pre-emphasis shapes a signal before it is sent and post-emphasis shapes it after it is received. The idea is to compensate for distortions that the transmission channel may/will introduce.
    Radars also sometimes use this to spread a pulse and thus transmit more power. Then on reception compress the pulse to improve range resolution.
  4. #4
    Join Date
    May 2002
    Posts
    1,184
    Points
    8,778
    Level
    22
    site:edaboard.com pre-emphasis
    please give me some OPAMP circuit for pre-emphasis and de-emphasis.
    •   Alt26th September 2007, 17:42
      advertising
  5. #5
    Advanced Member level 5
    Points: 12,565, Level: 26
    Borber's Avatar
    Join Date
    Jan 2000
    on third flor
    Posts
    1,602
    Points
    12,565
    Level
    26
    pre emphasis and de emphasis
    Deemphasis circuit is trivial. Use current generator which supply parallel RC whose time constant is 50us or 75us regarding what you need.
    •   Alt26th September 2007, 18:47
      advertising
  6. #6
    Newbie level 6
    Points: 844, Level: 6
    Join Date
    Aug 2009
    MALAYSIA
    Posts
    14
    Points
    844
    Level
    Re: Pre-emphasis and DE-emphasis circuits?
    any idea on matlab source code of this pre-emphasis FIR filter?
    I have 1 coding in my hand but the number of order is too high!!! i doesnt want the number of order higher than 32.
    Any idea?
  7. #7
    Newbie level 1
    Points: 398, Level: 4
    Join Date
    Oct 2010
    Posts
    Points
    398
    Level
    Re: pre emphasis and de emphasis
    [I need pre emphasis and de emphasis circuits using opamp
  8. #8
    Member level 3
    Points: 784, Level: 6
    dinosaur078's Avatar
    Join Date
    Sep 2011
    Posts
    55
    Points
    784
    Level
    Quote Originally Posted by zingade_se View Post
    dear you all
    in PCIe gen 3, why do we need preshoot technique ?
    thank you in advance
  9. #9
    Points: 34,278, Level: 45
    Achievements:
    7 years registered Created Blog entry Created Album pictures
    SunnySkyguy's Avatar
    Join Date
    Sep 2007
    Richmond Hill, ON, Canada
    Posts
    6,633
    Points
    34,278
    Level
    45
    Blog Entries
    7
    Since noise is constant per unit bandwidth , noise is thus greater with higher center frequency
    i.e. bass 50 ~500Hz is lower bandwidth than 500~15kHz so the treble is amplified on transmitter and reduced in receiver so response net is flat.
    I recall there is 15dB of pre-emphasis but I forget the breakpoint frequency.
    A good design question lists your overall requirements™ The best question deserves a better answer. ™
    ... Tony Stewart EE since 1975
  10. #10
    Member level 3
    Join Date
    Sep 2011
    Posts
    55
    Points
    784
    Level
    dear sunny ?
    could you explain more about preshoot in detail ?
    thanks
    •   Alt18th March 2014, 05:27
      advertising
  11. #11
    Achievements:
    Join Date
    Sep 2007
    Posts
    6,633
    Points
    34,278
    Level
    45
    Blog Entries
    7
    visualize treble control set to 15dB gain for Transmitter (Tx) and Receiver treble set to -15 dB before the equalizer.
    This is pre-emphasis..(Tx) and de-emphasis (Rx)
    not preshoot.
  12. #12
    Member level 3
    Join Date
    Sep 2011
    Posts
    55
    Points
    784
    Level
    i think there is a different view of PRESHOOT.
    this is its definition :
    " Preshoot is a new feature designed to improve the signal in the following bit time by boosting the voltage in the current bit time"
    why it can improve signal ?
    pls
