+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Member level 4
    Points: 1,327, Level: 8
    Join Date
    Aug 2007
    Posts
    69
    Points
    1,327
    Level
    8
    Why the gate oxide is thinner than field oxide ?
    hi...
    why the gate oxide is thinner than field oxide.
    •   Alt20th September 2007, 10:59
      advertising
  2. #2
    Full Member level 3
    Points: 2,603, Level: 11
    protonixs's Avatar
    Join Date
    Jul 2007
    PH
    Posts
    151
    Points
    2,603
    Level
    11
    quality of field oxide vs gate oxide
    i guess if the gate oxide is thick, the ability of the gate voltage to cause an inversion layer is weak.:D
  3. #3
    Junior Member level 3
    Points: 1,796, Level: 9
    Achievements:
    7 years registered
    Join Date
    Dec 2006
    Posts
    31
    Points
    1,796
    Level
    9
    gate oxide
    I think :
    first, the elctricity of the gate oxide is greater than field oxide. If the field oxide is thinner than gate oxide, the field oxide will be breakdown quicker than gate oxide while them on the same voltage.
    second. if the field oxide is thinner than gate oxide, the vth of the field is lower than gate oxide. so the parasitic devices will much more, and the circuit will not on work.
    •   Alt21st September 2007, 05:49
      advertising
  4. #4
    Member level 2
    Points: 1,611, Level: 9
    Join Date
    Sep 2007
    Posts
    47
    Points
    1,611
    Level
    9
    Re: gate oxide
    The gate oxide and the field oxide are totally two different thing.
    If you have some knowledge of semiconductor Device Phsics and semiconductor process,you will know the gate oxide is used to form the MOS(Metal_Oxide_Semiconductor) structure . To maintain the gate Voltage's control ove the conduction channel ,the gate oxide,more precisely the gate dielectric must not be too thick,in 130nm technology the gate oxide is 1.6nm thick,in 90 nm,it is about 1.2nm.
    the field oxide is used for the purpose of isolation and insulation.Isolate each transistors from each other and allow interconnect wires run on it without short. To avoid forming parasitic MOS structures in field oxide region,the field xoide is much more thick than gate oxide.
    1 members found this post helpful.
    •   Alt21st September 2007, 08:35
      advertising
  5. #5
    Junior Member level 1
    Points: 1,921, Level: 10
    Join Date
    Mar 2004
    Taiwan
    Posts
    17
    Points
    1,921
    Level
    10
    Re: gate oxide
    m...
    Another thing difference.
    To prevent field oxide parasitic leakage path, channel stop implant is always used, which is opposite to thin oxide.
  6. #6
    Member level 3
    Points: 1,906, Level: 10
    Achievements:
    7 years registered
    Join Date
    Sep 2006
    Posts
    64
    Points
    1,906
    Level
    10
    gate oxide
    gate oxide is grown oxide in dry environment & its quality is very good , whereas field oxide is also grown by wet/dry process .
  7. #7
    Advanced Member level 3
    Points: 6,226, Level: 18
    hr_rezaee's Avatar
    Join Date
    Oct 2004
    Iran-Mashhad
    Posts
    751
    Points
    6,226
    Level
    18
    gate oxide
    HI
    thin filed oxide generate large parasitic capacitor too.
    thin filed oxide generate parasitic MOSFET transistor too.
    regards
    •   Alt30th October 2007, 09:01
      advertising
  8. #8
    Points: 1,810, Level: 9
    Join Date
    Dec 2004
    Posts
    29
    Points
    1,810
    Level
    9
    Re: gate oxide
    Gate oxide is, and always will be thiner than field oxide...But why?? Well the answer rely on what are they used for.
    Field oxide: Isolate, IC Robustness, etc...
    Gate oxide: Makes part of the conception of a MOS transistor, will be thiner with the technology scalling for current drive issues...
  9. #9
    Member level 3
    Achievements:
    7 years registered
    Join Date
    Sep 2006
    Posts
    64
    Points
    1,906
    Level
    10
    gate oxide
    smaller the thickness , higher the capacitance ,more the control of gate , ..
