+ Post New Thread
Page 1 of 10 1 2 3 ... LastLast
Results 1 to 20 of 193
  1. #1
    Junior Member level 2
    Points: 1,630, Level: 9
    santapg's Avatar
    Join Date
    Dec 2006
    Kolkata, India
    Posts
    22
    Points
    1,630
    Level
    9
    Blog Entries
    laptop motherboard repair guide
    Hi! I am Sandip Golani engaged in chip-level repairing of Laptop & desktop motherboard, If Any one of u have any problem, Pls. Place u r question in the forum, I will reply over here. I am Ready to share my 15 years experiance with EDAboard.com. My Website Address Is www.compudrivesystem.com.
    •   Alt18th September 2007, 11:40
      advertising
  2. #2
    Full Member level 1
    Points: 2,594, Level: 11
    Achievements:
    7 years registered
    Join Date
    Feb 2006
    Fayoum, Egypt
    Posts
    99
    Points
    2,594
    Level
    11
    desktop motherboard repair
    yes. I have an Inpisron 1500 Dell laptop. It has a DVD compo . It can read DVD only but can bot read CDs. what is the problem?
    3 members found this post helpful.
  3. #3
    Advanced Member level 2
    Points: 7,347, Level: 20
    the_risk_master's Avatar
    Join Date
    Aug 2005
    UE+MIT, Philippines, (14°N , 120°E )
    Posts
    662
    Points
    7,347
    Level
    20
    sandip golani
    I have messed with my laptop 5 months ago, I was then experimenting on the parallel port barely with some transistors and suddenly these transistors "feedback" a signal spike to the port and shut off dead my laptop, I was trying to repair it but when I opened it, none of the chips inside is burnt,
    btw, my laptop model is Compaq Evo N600C
    what chip should I be focusing on, I have also a repair manual of it, but it doesnt help me
    I'll be waiting for some response
    cheers!
    the_risk_master
    2 members found this post helpful.
  4. #4
    santapg's Avatar
    Join Date
    Dec 2006
    Kolkata, India
    Posts
    22
    Points
    1,630
    Level
    9
    Blog Entries
    how to test laptop motherboard
    Hi! FM-COM-28
    Atlest can give your name. There is a preset at the bottom of the cd drive lens, rotate it to allign it, but very slowly or allignment of dvd will also get distrub.
    Find out the preset. Its under the optical head.
    Bye
    Added after 3 minutes:
    Hi! The Risk Master
    Its Sandip Golani. See parallel port is directly connected to LPC. Stands for Low Pin Count IC, its is generally 128 pin ic Quad Pack. But I Doubt that a decoupling cap. has shorted therefore the laptop has konged off.
    Check all decoupling cap. there will be 17 in nos. 8 in data line, 4 in control line and 5 in status line.
    Bye
    Replay what happens.
  5. #5
    santapg's Avatar
    Join Date
    Dec 2006
    Kolkata, India
    Posts
    22
    Points
    1,630
    Level
    9
    Blog Entries
    how to test a laptop motherboard
    No More Query today
    Sandip Golani
  6. #6
    santapg's Avatar
    Join Date
    Dec 2006
    Kolkata, India
    Posts
    22
    Points
    1,630
    Level
    9
    Blog Entries
    how to check laptop motherboard
    Hi! what happen no more qurey today
  7. #7
    santapg's Avatar
    Join Date
    Dec 2006
    Kolkata, India
    Posts
    22
    Points
    1,630
    Level
    9
    Blog Entries
    laptop circuits
    Don't leave your battery unused for long periods of time. Even if you use AC power most of the time, use the battery regularly to keep it in good condition. Switch off your AC adapter when the laptop is not in use. This prevents overcharging.
    To extend battery life, you can try decreasing the LCD brightness while using your notebook. You can activate the `Standby' and `Hibernation' power saving modes, too, for better battery life, you can put off the Wi-Fi when not in use.
    If you do not use your laptop for extended periods of time-a week or more remove the battery pack from the laptop, but only after discharging it fully.
    No eating and drinking near or around your laptop. The least bit of water could short-circuit some sensitive laptop circuits, and render it useless.
    You may sometimes be tempted to turn your laptop off by simply holding down the power button until it powers down. Although quick, this method is harmful to the laptop and could cause data loss. A hard reboot should only be used as a last resort. Sometimes this is inevitable, for instance, when Windows hangs. But this should not be a regular practice.
    Don't subject your laptop to jerks and shocks. This will help avoid damage to your hard drive. Preferably, power the notebook off before moving it from one place to another.
    External peripherals and accessories such as external optical drives, PC cards and USB keyboard lights draw power from the notebook. Disconnect such devices when not in use.
    Booting the notebook when it is not connected to a power source draws a lot of power from the battery. Instead of shutting down your laptop in the middle of a meeting, choose the `Suspend' mode if you wish to use it again after just a short interval. This will save battery and help you restart your work faster.
    If you have just shut down your laptop, give it 30 seconds before you start it up again. This ensures that the hard drive has spun down, and is not subjected to sudden switching on and off.
    Don’t put on the laptop keeping of cloth or bed because generally the air flow is from bottom, regular doing so may reduce the life of laptop circuit.
    Don’t press very hard the laptop keyboard because, if damaged can cost very high, therefore while playing game use external keyboard.
    Hope u readers will like it
    1 members found this post helpful.
  8. #8
    santapg's Avatar
    Join Date
    Dec 2006
    Kolkata, India
    Posts
    22
    Points
    1,630
    Level
    9
    Blog Entries
    Monday i will be posting tips on purchasing secondhand laptop.
  9. #9
    santapg's Avatar
    Join Date
    Dec 2006
    Kolkata, India
    Posts
    22
    Points
    1,630
    Level
    9
    Blog Entries
    testing laptop motherboard
    1. Laptop is used to carry from place to place…so people who travel a lot must think of the weight of the laptop.
    2. Every battery has a lifetime. So going for a Laptop with hardly any battery backup is not suggested. Minimum of 45 minutes battery backup is very necessary. So while purchasing the secondhand laptop please keep in mind to check the laptop only on battery for minimum 30 minutes and also keep an eye on battery usage indicator.
    3. Carry with yourself an audio, video & Blank CD/DVD so that u can check the audio section and video section of the laptop including the CD/DVD read/write test.
    4. Run the scandisk utility available in all versions of windows and check for bad sector in hard disk.
    5. Take with yourself any external device like thumb drive to test the USB port.
    6. Take with yourself SD memory card to test Card Reader (If the option is available on the laptop)
    7. Take any good floppy to test the floppy drive (Any how current Laptops are not coming with Floppy Drive)
    8. Take an external headphone and microphone to test the external audio port.
    9. Attach the laptop to the external monitor to check the external VGA port is working or not.
    10. Open any word file and check all the keys are working or not.
    11. Check for battery charging for 5 to 10 minutes and see the battery indicator is showing charging.
    12. Press the window and the break keys on the keyboard and see the amount of RAM and CPU details. Further chick the hardware option and then the Device manager to see all driver are installed or not. There should be no Exclamation mark.
    13. Slide the LCD screen slowly on the hinges and check any flicker on the display if so there may be a problem on the connector cable driving the LCD circuit of the laptop.
    14. Also check the Modem, Bluetooth & Wi-Fi Port if available on your laptop to be purchased (Do only if you know) I will be writing on these subject next.
    15. Check the laptop minimum for 45 minutes to see whether laptop hangs or restarts or shutdowns.
    16. See the Laptop User manual and Driver CD are there with the Laptop.
    17. See that u get a laptop carry case, otherwise u have to purchase one.
    18. If all the conditions meets out OK and within your budget just go for it.
    19. Happy LAPTOPing.
    •   Alt27th September 2007, 09:34
      advertising
  10. #10
    Member level 2
    Points: 1,304, Level: 8
    Join Date
    Mar 2007
    Posts
    44
    Points
    1,304
    Level
    8
    how to repair desktop motherboard
    hi sant
    I am 845chip set intel orginal motherboard,which is troubling almost a year.i replaced twice with intel,but problem continues..problem is thermal heating?its shutting down automatically after 15-20 min from boot up.give me solution?I am really fed up with this?help me out?
    •   Alt27th September 2007, 11:53
      advertising
  11. #11
    Join Date
    Aug 2005
    Posts
    662
    Points
    7,347
    Level
    20
    laptop motherboard fuses
    Hi Sandip Golani,
    Sorry for the long wait, Okay, there's the LPC with decoupling caps, how should I check those? (sorry for my ignorant questions, and please keep this thread alive I need to fix my laptop)
    Thanks all, esp. to s. golani
    the_risk_master
  12. #12
    Banned
    Points: 5,790, Level: 18
    Join Date
    Jun 2005
    scotland uk
    Posts
    646
    Points
    5,790
    Level
    18
    sony pcg-k86p wireless adapter not connecting
    Quote Originally Posted by the_risk_master
    cheers!
    the_risk_master
    i would look closer at the psu section
    as your laptop is dead its very likely that a small ceramic fuse has gone
    on or around the +5v supply
    its even more likely its this if you were drawing the power from the laptops +5vrail for your 'experiment' as all the i/os are double buffered it wont be the main driver i/c or the decoupling caps 'highly unlikely'
    most newer laptops use surface mount fuses or they are resistors marked 000
    some are small glass looking resistor sized
    and have a squiggle of metal in a zigzag
    or they can be the only of one or two thru hole type resistors
    or can be square long tube made of ceramic and are white
    youll find the main ones on the board that connects the battery and not sometimes on the main board
    a tip is this
    all the chips in a chipset must pass a post test for operation of a boot
    the machine beeps and then boots ? do the lights come on any??
    or is it dead as dead
    if lights come on then its an individual chips supply thats missing
    if no lights at all its the main supply rails to the whole main board
    if it were a periferal like memory cards
    or mpu missing keyboard etc
    then the beep sequence will appear
    daa da da da forinstance is a memory problem
    faulty supply to a chip in the chipset or a fried chip in the set
    will not allow even the beeps just lights
    Quote Originally Posted by fm_com_28
    as for the cdrom that wont read cd's except at boot time but will work ok with dvd
    when in windows but not cd in windows
    i notice you said it will boot a cd disk
    therefore its better to look to windows etc as the problem
    the drive is NOT bad
    and DONT adjust the focus balance pot as mentioned above
    or youll kill the drive for good
    if your going to at least draw a marker accross it
    so as to put it back when you find out its not bad
    its just the windows driver windows has decided to use
    some internal drives in laptops need there own ide drivers to be able to address the drive properly in all modes
    some use special software to make the drive read quietly and this can cause an issue
    if you can get a fresh ide 2.5" drive and attach it and install a plain copy of windows xp sp1
    im sure then it will work
    Quote Originally Posted by meetspraveen
    hi sant
    the heat pipe on the cpu cooling has a developed a 'fracture'
    the pipe carries away heat to the main cooler from the mpu
    you could find your battery voltage has climbed
    yes climbed
    some battery packs get so bad
    they output a couple of volts more causing thermal stress
    try a new battery and a different psu
    if this isnt a laptop as you didnt say then its more likely the mpu is gubbed and has become past its normal spec so replace it esp if
    its also in a socket and it is indeed a laptop you have remember you need a mobile type chip
    this problems can be caused by another drive or part next to or around the system tempreture detector and not always the main board
    see what tempreture it shuts down becouse of is it system or mpu ?? overheat
  13. #13
    santapg's Avatar
    Join Date
    Dec 2006
    Kolkata, India
    Posts
    22
    Points
    1,630
    Level
    9
    Blog Entries
    hbl50 la-2922p
    Hi Members
    Sorry For Delay Today Busy I will Replay Tomorrow.
    Thanks
  14. #14
    santapg's Avatar
    Join Date
    Dec 2006
    Kolkata, India
    Posts
    22
    Points
    1,630
    Level
    9
    Blog Entries
    symptom of short mother board circuit
    what happened no query on EDA board
  15. #15
    Junior Member level 1
    Points: 1,162, Level: 7
    Join Date
    Jul 2007
    Posts
    17
    Points
    1,162
    Level
    7
    packard bell e2316 broken laptops
    have desktop made by polar
    when first boot get to the windows logo
    and freezes if i press reset next boot from menu (windows failed to load)select normal boot
    boots ok works all day
    why not boot first time?
    have tried new psu new memory new motherboard batery
    was windows 98 have upgraded to me
    still same
    thans vince
  16. #16
    Advanced Member level 1
    Points: 4,811, Level: 16
    Achievements:
    7 years registered
    Old Nick's Avatar
    Join Date
    Sep 2007
    Posts
    480
    Points
    4,811
    Level
    16
    Hi Sandip,
    I'm not sure if you can help or not, but my PC has been playing up for a while now. A few months ago it started overheating (and shutting down), for no discernable reason, the vents were clear the fans were all working, but the case was quite hot. This only lasted for a couple of days, and it seemed to be OK, however it is still running quite hot. And when I first boot my PC, the fan monitor (ASUS probe) tells me that my CPU fan is not spinning (which of course it is), for about a minute, then it seems to be able to sense it's speed and the warning goes away.
    Apart from the fan warning and the heat, everything seems to be fine.
    The MB is an ASUS a7n8x v2 delux with a Athlon xp2500.
    Cheers,
    Nick
  17. #17
    Newbie level 1
    Points: 930, Level: 6
    Join Date
    Oct 2007
    Posts
    Points
    930
    Level
    i have trouble with my laptop (toshiba tecra8000)
    fl inverter with part no UA0392P06 is dead, so my laptop lcd shown dark
    (ccfl / neon backlight lamp and fuse is fine)
    i try to find schematic / circuit for it (fl inverter) but never come to me.
    can you help me with my trouble, please give me schematic for fl inverter or anything about fl inverter ; how it works, basic circuit, etc
    thanks before :D
  18. #18
    Newbie level 3
    Points: 960, Level: 7
    Join Date
    Oct 2007
    Posts
    Points
    960
    Level
    7
    laptop motherboard testing
    Hi Sandeep,
    I have a problem with my Dell Inspiron 8100 laptop. when I slide the LCD
    It display some lines or rainbow of colours.I want to know the problem is in
    connector cable or TFT
  19. #19
    santapg's Avatar
    Join Date
    Dec 2006
    Kolkata, India
    Posts
    22
    Points
    1,630
    Level
    9
    Blog Entries
    laptop motherboard tester
    Quote Originally Posted by hanaphie
    thanks before :D
    Hi Henapaie
    It is a basic osc circuit or a simple invertor circuit u can also use any invertor circuit which converts DC 18 volts to AC 150 to 180 volts
    Sandip Golani
    Hi
    Your PC Asus motherboard is overheating it is due to over current drawn by may be the CPU or the North Bidge IC, or it can also be CPU core regulator is running under currrent. This needs a complete checkup in CHIP LEVEL. SO if u can proceed tell me i will guide..
    Sandip Golani
    •   Alt8th October 2007, 11:15
      advertising
  20. #20
    santapg's Avatar
    Join Date
    Dec 2006
    Kolkata, India
    Posts
    22
    Points
    1,630
    Level
    9
    Blog Entries
    thermal heating error in intel d915glvg
    what happen no more query to day
    Sandip Golani
