+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Junior Member level 2
    Points: 1,090, Level: 7
    Join Date
    Sep 2007
    Posts
    24
    Points
    1,090
    Level
    7
    mosquito killer circuit
    :D How does Electric Mosquito Killer bat work, and send us the circuit as well as the part spec...:idea:
    •   Alt13th September 2007, 15:06
      advertising
  2. #2
    Advanced Member level 5
    Points: 17,526, Level: 32
    Join Date
    Oct 2005
    India
    Posts
    1,804
    Points
    17,526
    Level
    32
    electronic mosquito killer circuit
    it just uses high voltage through the adjacent wires... if i remem well, inductors are used for generating them using inductive kickback that is why it isnt that harmful to us....
    4 members found this post helpful.
    •   Alt13th September 2007, 17:06
      advertising
  3. #3
    Super Moderator
    Points: 25,530, Level: 38
    andre_teprom's Avatar
    Join Date
    Nov 2006
    Brazil
    Posts
    7,682
    Points
    25,530
    Level
    38
    Blog Entries
    electric mosquito killer circuit
    I uses just a push-pull inverter with a transformer, switched at around 2KHz.
    •   Alt13th September 2007, 17:25
      advertising
  4. #4
    Join Date
    Oct 2005
    India
    Posts
    1,804
    Points
    17,526
    Level
    32
    mosquito killer bat circuit
    k... this is the basic idea that i was talkin about.... we use a square wave generator which at its output has a diode and inductor connected in series.... when the output of the square wave generator goes low the inductor shows kickback and the diode protects the square wave generator by going to reverse bias... the square wave and the inductor determine the working voltage....
    1 members found this post helpful.
