+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Junior Member level 3
    Points: 1,349, Level: 8
    Join Date
    Aug 2007
    Posts
    28
    Points
    1,349
    Level
    8
    How to invert 12V Dc car battery to 230V Ac ?
    How to invert car battery 12V Dc to 230V Ac
    •   Alt6th September 2007, 17:34
      advertising
  2. #2
    Super Moderator
    Points: 26,013, Level: 39
    andre_teprom's Avatar
    Join Date
    Nov 2006
    Brazil
    Posts
    7,844
    Points
    26,013
    Level
    39
    Blog Entries
    Re: Inverters
    By a simple push-pull topology circuit with transformer.
  3. #3
    Advanced Member level 2
    Points: 7,635, Level: 20
    Mr.Cool's Avatar
    Join Date
    Jun 2001
    Posts
    664
    Points
    7,635
    Level
    20
    Inverters
    goto walmart and buy a 50$ inverter!
    Mr.Cool
    •   Alt8th September 2007, 16:59
      advertising
  4. #4
    Advanced Member level 5
    Points: 17,526, Level: 32
    Join Date
    Oct 2005
    India
    Posts
    1,804
    Points
    17,526
    Level
    32
    Re: Inverters
    you would have to design an oscillator and then use transformer to step up the output,,,
  5. #5
    Member level 3
    Points: 1,574, Level: 9
    Join Date
    Feb 2006
    Posts
    62
    Points
    1,574
    Level
    9
    Re: Inverters
    first of all to convert 12V to 230V the amperage should be high enough..
    Although it is 12V it should be about like 5 to 10 A.
    Now use a chopper circuit to convert DC to Intermittent square wave of 50 Hz/60 Hz.
    Then you can use a square to sine wave converter to smooth-up your output for a perfect phase lag between V and I.
    Later use a corresponding 50/60 Hz step up transformer to obtain required voltage.
  6. #6
    Newbie level 3
    Points: 1,084, Level: 7
    Join Date
    Jan 2007
    Posts
    Points
    1,084
    Level
    7
    Re: Inverters
    Quote Originally Posted by pnnavigator0915
    With this u can use the equation: V2/V1=N2/N1 to get no. of turns on transformer...
  7. #7
    Mr.Cool's Avatar
    Join Date
    Jun 2001
    Posts
    664
    Points
    7,635
    Level
    20
    •   Alt14th November 2007, 04:59
      advertising
  8. #8
    Full Member level 5
    Points: 3,191, Level: 13
    Achievements:
    7 years registered
    Join Date
    Apr 2007
    Nigeria
    Posts
    244
    Points
    3,191
    Level
    13
    Re: Inverters
    Quote Originally Posted by nnm
    to make a cheap one get a 555 timer and configure it in an astable mode. for a better frequency stability generate about 100hz or 120hz and divide it by using a JK type or a Dtype flipflop to divide the it to two 50hz or 60hz two banks. then you will have to wave one inverted and the other not inverted. using transistor one or two for each bank usually an NPN (BC547 or SL 100) for amplification may be in darlignton mode or emitter follower. then for driving the transformer you will need two banks of power fets or transistors 2n3055 or TIP 142 or IRF250 (get their datasheet for their connection) connect collector or the drain of the power tansistors or fets to the transformer. the transformer should be of 12v -ov - 12v secondary side and primary 110 or 220v more or less power should depend on the load to serve and your judgement. experiment with this first and lets hear your feedback.
    PLS IF YOU HAVE NO PRIOR KNOWLEDGE OF ELECTRICAL POWER PLS DONT ATTEMPT TO DO THIS HAS HIGH VOLTAGE IS INVOLVED. PUT SAFETY FIRST
