+ Post New Thread
Results 1 to 14 of 14
  1. #1
    Member level 3
    Points: 1,502, Level: 8
    Join Date
    Apr 2006
    Posts
    62
    Points
    1,502
    Level
    8
    radians to mm
    dear frnds,
    plz tell me formula to convert radian or degree to mm or cm.............its very much required in my frnd's project.........
    thanks in advance
    regards
    JSPS
  2. #2
    Advanced Member level 5
    Points: 74,061, Level: 66
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    conversion radians to meters
  3. #3
    Member level 3
    Join Date
    Apr 2006
    Posts
    62
    Points
    1,502
    Level
    8
    mm to radians
    dear frnd,
    i want to convert radian to mm
    please advise
    regards
    JSPS
    •   Alt30th August 2007, 12:26
      advertising
  4. #4
    Advanced Member level 1
    Points: 4,907, Level: 16
    Join Date
    Jul 2005
    Posts
    452
    Points
    4,907
    Level
    16
    radians to meters conversion
    Your question is ambiguous. Radian is a measure
    of angle and mm is a measure of distance.
    Would you please reformulate your question?
  5. #5
    Member level 3
    Join Date
    Apr 2006
    Posts
    62
    Points
    1,502
    Level
    8
    degree to mm conversion
    no mr. jallem,
    question is correct..........
    please advise
    regards
    JSPS
  6. #6
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    You insist on converting totally incompatible measures such as angle and length ..
    Are you serious, or is it just a joke???
    Regards,
    IanP
    •   Alt30th August 2007, 15:22
      advertising
  7. #7
    Full Member level 2
    Points: 2,874, Level: 12
    MSRA's Avatar
    Join Date
    Nov 2006
    NED Pakistan
    Posts
    130
    Points
    2,874
    Level
    12
    meters to radians conversion
    radian
    has dimensions of
    plane-angle
    Note that plane-angle is not an official metric (SI) dimension
    millimeter
    has dimensions of
    length
    If both the units have same dimensions then only they can be inter changes..
    and as radian is from plane angle and mm is from length they cann't be converted
  8. #8
    Full Member level 1
    Points: 3,054, Level: 13
    Join Date
    Apr 2005
    Spain
    Posts
    108
    Points
    3,054
    Level
    13
    convert radians to meters
    look at:
    h**p://www.themathpage.com/aTrig/arc-length.htm
  9. #9
    Newbie level 3
    Points: 950, Level: 6
    Join Date
    Sep 2007
    Posts
    Points
    950
    Level
    convert radian to mm/m
    you need for this question to determine radius of circle then if multiple radius to angle value you have quantity with length dimension as dimension of radius.
  10. #10
    Points: 12,011, Level: 26
    Join Date
    Mar 2005
    USA
    Posts
    1,326
    Points
    12,011
    Level
    26
    mm to radian
    jsps,
    Radian ia an angular quantity and is dimensionless. If you are interested in determining the arc length (l) on a circle subtended by an angle in radians, use the formula l = wr, where r is the radius, w is the radian angle.
    Regards,
    Kral
    •   Alt6th September 2007, 04:25
      advertising
  11. #11
    Join Date
    Jul 2005
    Posts
    452
    Points
    4,907
    Level
    16
    radian a milimetros
    Quote Originally Posted by jsps
    no mr. jallem,
    please advise
    regards
    JSPS
    Some people are just stuborn......
  12. #12
    Full Member level 6
    Points: 2,999, Level: 12
    Join Date
    Aug 2006
    Bikini Bottom, between a rock and a pineapple
    Posts
    339
    Points
    2,999
    Level
    12
    convert mm to rad
    Mr. Jallem, my friends ask me to convert from temperature to second, could you tell me how?
    Glad I'm not that...you know.
    Learn trigonometry kid!
    Added after 50 seconds:
    If you ask steradian to mm, its possible.
  13. #13
    Newbie level 3
    Points: 920, Level: 6
    Join Date
    Jan 2008
    Posts
    Points
    920
    Level
    formula to convert mm to french
    It's exactly like someone asking how to convert amperes into tomatoes.
    TOTALLY INCOMPATIBLE UNITS!
    To do a conversion between mm and radians, you need a circle of a known radius (example, using a circle with a 1 meter radius, a radian would measure 1000mm) which is NOT the case in the JSPS's question.
  14. #14
    Banned
    Points: 5,691, Level: 17
    Join Date
    Sep 2007
    Posts
    853
    Points
    5,691
    Level
    17
    mm to uradians
    dear frnds,
    thanks in advance
    regards
    JSPS
    An arc characterized by an angle of A radian and having a radius of R meter has a length equal to AxR meter.
    Your question was not too complicated to be misunderstood.
