What's the difference between cross compiler and compiler ?
naresh850
Full Member level 3
Wats the difference between cross compiler and compiler
Re: cross-compiler
A cross compiler is a compiler capable of creating executable code for a platform other than the one on which the compiler is run. Cross compiler tools are generally found in use to generate compiles for embedded system or multiple platforms. It is a tool that one must use for a platform where it is inconvenient or impossible to compile on that platform, like microcontrollers that run with a minimal amount of memory for their own purpose. It has become more common to use this tool for paravirtualization where a system may have one or more platforms in use.
Uses of cross compilers
The fundamental use of a cross compiler is to separate the build environment from the target environment. This is useful in a number of situations:
Embedded computers where a device has extremely limited resources. For example, a microwave oven will have an extremely small computer to read its touchpad and door sensor, provide output to a digital display and speaker, and to control the machinery for cooking food. This computer will not be powerful enough to run a compiler, a file system, or a development environment. Since debugging and testing may also require more resources than is available on an embedded system, cross-compilation can be more involved and prone to errors than native compilation.
Compiling for multiple machines. For example, a company may wish to support several different versions of an operating system or to support several different operating systems. By using a cross compiler, a single build environment can be set up to compile for each of these targets.
Compiling on a server farm. Similar to compiling for multiple machines, a complicated build that involves many compile operations can be executed across any machine that is free regardless of its brand or current version of an operating system.
Bootstrapping to a new platform. When developing software for a new platform, or the emulator of a future platform, one uses a cross compiler to compile necessary tools such as the operating system and a native compiler.
Use of virtual machines (such as Java's JVM) resolves some of the reasons for which cross compilers were developed. The virtual machine paradigm allows the same compiler output to be used across multiple target systems.
Typically the hardware architecture differs (e.g. compiling a program destined for the MIPS architecture on an x86 computer) but cross-compilation is also applicable when only the operating system environment differs, as when compiling a FreeBSD program under Linux, or even just the system library, as when compiling programs with uClibc on a glibc host.
