+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Member level 4
    Points: 1,429, Level: 8
    Join Date
    Jan 2007
    Posts
    75
    Points
    1,429
    Level
    8
    How to the find critical path delay of a design using Design Compiler
    how to the find critical path delay of a design using Design Compiler
    any material would be of great help
    thank you
    •   Alt18th August 2007, 11:28
      advertising
  2. #2
    Banned
    Points: 5,639, Level: 17
    Achievements:
    7 years registered
    Join Date
    Nov 2005
    Fleet, UK
    Posts
    413
    Points
    5,639
    Level
    17
    Re: critical path delay
    1. Read in your design in to design compiler
    2. report_timing
    It will give you the critical path delay.
    you can see some more commands at
    http://www.vlsiip.com/dc_shell
    Kr,
    Avi
    •   Alt18th August 2007, 11:42
      advertising
  3. #3
    Full Member level 5
    Points: 2,966, Level: 12
    Achievements:
    7 years registered
    Join Date
    Jul 2007
    Tokyo
    Posts
    245
    Points
    2,966
    Level
    12
    report_constraint -all_viol -max_delay will give all violating paths in each path group. Path groups are depends on the number of clocks in your design(default) else u can also specify path groups ..
    report_qor will also tells, in each path groups ,whats the path delay ..
    Regards,
    Sam
