the difference of algorithm and architecture in css
nozone
Member level 3
newbie on this, seems I can only use algorithm to generate the RTL, right?should I use the architecture to generate the test bench, I mean how to use them properly?
no thanks in this forum, so thanks in advance :p
algorithm : untime function model
(data flow, control flow, floating to fixed)
Only samples be calculated.
architecture : SystemC model
(Time model, TL model, Cycle accuracy model, or RTL model)
Code by yourself.
