+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Junior Member level 2
    Points: 1,198, Level: 7
    Join Date
    Apr 2007
    Philippines
    Posts
    22
    Points
    1,198
    Level
    7
    op amp voltage divider
    Just wondering, can an op-amp be used as a buffered voltage-divider instead of introducing gain in a circuit.
    •   Alt7th August 2007, 07:54
      advertising
  2. #2
    Advanced Member level 5
    Points: 17,526, Level: 32
    Join Date
    Oct 2005
    India
    Posts
    1,804
    Points
    17,526
    Level
    32
    op amp divider
    give the output of the voltage divider to a voltage follower... thus the voltage dividers output gets buffered as well as is independent of the load since the input current of op amp is zero...
  3. #3
    Member level 1
    Points: 1,130, Level: 7
    Join Date
    Aug 2007
    Posts
    32
    Points
    1,130
    Level
    7
    op amp divider circuit
    An op amp used in an inverting amplifier configuration can have any gain including less than one. Thus is can be used as a buffered voltage divider.
    •   Alt8th August 2007, 15:52
      advertising
  4. #4
    Junior Member level 3
    Points: 1,411, Level: 8
    ck84's Avatar
    Join Date
    Jan 2006
    Posts
    26
    Points
    1,411
    Level
    8
    opamp divider
    But the gain will be negative. So be careful if your circuit doesn't have reverse protect. I will use the op amp as an adder of two or more other op amps with both inverting and non-inverting gains.
  5. #5
    Member level 2
    Points: 2,316, Level: 11
    Join Date
    Mar 2006
    Posts
    49
    Points
    2,316
    Level
    11
    voltage divider op amp
    if u require help then contact me
    Added after 21 seconds:
    do contact
    1 members found this post helpful.
  6. #6
    Member level 4
    Points: 1,590, Level: 9
    Join Date
    Jan 2007
    Posts
    79
    Points
    1,590
    Level
    9
    op-amp as divider
    why would you want to do a divider with an op-amp, when it can be done much more cheaply with resistors?
    -M
    •   Alt10th August 2007, 00:03
      advertising
  7. #7
    Member level 4
    Points: 2,036, Level: 10
    Achievements:
    7 years registered
    Join Date
    May 2007
    Posts
    74
    Points
    2,036
    Level
    10
    op-amp voltage divider
    Because any resistive load on that simple resistor divider will mess up your division accuracy, not to mention it might be fairly high impedance node which might be susceptible to noise. You want to use the op-amp as a buffer so you can drive your reference over wider varying loads.
