Current Mode Design vs Voltage mode designs
swagata
Member level 3
current mode vs voltage mode
Hallo everybody!
Current Mode designs are extremely becoming popular now. I invite a general comparison of it with voltage mode designs.Any highlights on the advantage & disadvantage of both methods would be beneficial.
current mode design
you can refer to Dr. Ridley's paper <Voltage mode or current mode>
Plz give me the link
the main advantage of current mode design is that signal is unattenuated while being transmitted through a resistance which is the most significant factor of most components... whereas voltage when transmitted gets attenuated due to resistance which cannot be avoided...
    swagata
then current mode must be concerned with conductive loss...
what are you meaning by conductive loss... because whether it is a capacitor or inductor or resistor that is modeled in the transmission line it is gonna be in parallel and hence the current is not going to be reduced...
Thanks for the discussion.
Plz enlighten me comparing the followings in voltage with current mode.
1.voltage swing/current swing
2.input range
3.impedance
4.slew rate
5.linearity
You can also give me related lectures/tutorials in pdf/link.
Thanks again
voltage swing would be more in voltage mode design
current swing would be more in current mode design
input range,slew rate and linearity depends on the system for both. lots of trade off will be involved....
output impedance of voltage mode is low and it is high for current mode....
hi all
i think the posts above misunderstand what the first author want to discuss.
some people talked about the conceptions of voltage mode and current mode, these i think used mostly in power electronic ic domain.
but i think the first post want to know is, in general analog ic part, what is the difference between voltage and current mode.
correct me if i'm wrong.
good luck
jeff
see this book
the author of the book is professor at my university, he also gave us these brief review notes
    swagata
Thanx to all those who have participated in the discussion & shared their resources here.
Jfyan is also right that I m seriously interested in Analog IC part mainly.But every contribution has enlightened me in their own way.
Thanx again
Thanks to all.
I also want to design the Buck step-down dc-dc converter.
