+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Full Member level 3
    Points: 2,026, Level: 10
    Join Date
    Jul 2007
    Posts
    170
    Points
    2,026
    Level
    10
    What does it mean that FSM state register is one-hot?
    What does it mean for the statement below:
    "FSM state register should always be one-hot"
    Thanks in advance for your help
  2. #2
    Full Member level 5
    Points: 4,114, Level: 15
    Achievements:
    7 years registered
    RBB's Avatar
    Join Date
    Jul 2007
    USA
    Posts
    304
    Points
    4,114
    Level
    15
    FSM state register?
    One hot state machines have only a one signal in the state register is a '1'.
    For example
    State A: 0001
    State B: 0010
    State C: 0100
    State D: 1000
    One-hot state machines can be bigger than normal binary encoded state machines, but the next state decode is usually smaller in a one-hot state machine.
    Also notice a one-hot state machine is hamming encoded, so that two bits must change for a valid state transition
    1 members found this post helpful.
    •   Alt1st August 2007, 15:43
      advertising
  3. #3
    Full Member level 3
    Join Date
    Jul 2007
    Posts
    170
    Points
    2,026
    Level
    10
    Re: FSM state register?
    Thanks for your reply RBB.
    Let say i have state machine below
    State A ( 0 ) : 0000
    State B ( 5 ) : 0101
    State C ( 10 ) : 1010
    Above is my FSM. But i have more than 1 signal have logic 1.
    So how can the FSM state register should always be one-hot?
    •   Alt2nd August 2007, 02:58
      advertising
  4. #4
    Full Member level 5
    Points: 2,966, Level: 12
    Achievements:
    7 years registered
    Join Date
    Jul 2007
    Tokyo
    Posts
    245
    Points
    2,966
    Level
    12
    One-hot encoding sets one bit in the state register for each state. For ex, FSM with 16 states required 16 FF`s for one hot encoding.
    Each node of the state diagram in one-hot encoding is implemented with one FF. There are lot of unused states in the One-hot encoding. If you use N FF , there will be 2 power N used states , 2 power N - N states are unused states.
    In your example, to represent 5 , you need to specify 10000 not 0101...and etc..
    There are diffrent FSM encoding style including One-hot, are Adjucent encoding, Random encoding, User-Specific encoding, Moore encoding, Binary encoding and etc..
    Regards,
    Sam
    •   Alt2nd August 2007, 03:36
      advertising
  5. #5
    Full Member level 3
    Join Date
    Jul 2007
    Posts
    170
    Points
    2,026
    Level
    10
    cool sam
    your reply is really helpful.
  6. #6
    Full Member level 2
    Points: 1,852, Level: 10
    Join Date
    Jul 2007
    bangalore
    Posts
    132
    Points
    1,852
    Level
    10
    FSM state register?
    hi
    FSM is the finite state machine is used for control logics.
    one hot machine is each state taken one FF ex:-0001
    it is reduecd glitch
    binary state machine is the taken FF s depend on the state 2N= state ,N is the no .of FF
    it is used for reduecd area.
    vamsi
    Added after 35 seconds:
    hi
    vamsi
    •   Alt2nd August 2007, 09:17
      advertising
  7. #7
    Full Member level 1
    Points: 1,748, Level: 9
    Join Date
    Jul 2007
    India
    Posts
    112
    Points
    1,748
    Level
    9
    The only advantage of using one-hot Fsm is the elimination of decoder...
  8. #8
    Full Member level 2
    Points: 2,241, Level: 10
    Join Date
    Mar 2004
    Posts
    147
    Points
    2,241
    Level
    10
    FSM state register?
    fsm state coding depends on your choice, one-hot use more register but give u high speed.
  9. #9
    Full Member level 2
    Points: 1,895, Level: 10
    Join Date
    Jun 2007
    Posts
    122
    Points
    1,895
    Level
    10
    Can One - Hot encoding makes data path short.
    If yes how?
  10. #10
    Full Member level 2
    Join Date
    Mar 2004
    Posts
    147
    Points
    2,241
    Level
    10
    FSM state register?
    it relies on how many state your FSM has
    when the state number is big and require high speed
    then one-hot is a best choice
