Spiral Inductor in ADS
Sadegh.j
Advanced Member level 3
Hello
How do you define a spiral inductor in ADS?
Hi
As far as I remember there is a toolbar where there are some spiral inductors...
Otherwise you would need a designkit.
Dunno if this was what you were looking for?
Regards
If you need some constant value and don't care much about topology - use componets from "TLine_Microstrip".
Or just draw a topology of the inductor, simulate it, and calculate the value - very usefull empirical method.
If you good at programming, you can on the "ael" language programm the topologies (rectangular, circle) of the inductors and with such script generate needed topologies - it saves a lot of time.
Thanks guys, can you use the port name INDQ?
Added after 2 minutes:
I have done a lot of programming, but what is ael?
