+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Full Member level 3
    Points: 2,638, Level: 11
    Join Date
    Oct 2004
    Nanshan, Shenzhen
    Posts
    188
    Points
    2,638
    Level
    11
    characterizing operational amplifier
    hi,all,
    how to simulate and measure the input/output impedance of operational amplifier. pls give me some methods. can you give me some papers about analysis and simulation of operational amplifiers. thanks in advance!
    kind regards,
    •   Alt25th July 2007, 11:15
      advertising
  2. #2
    Full Member level 2
    Points: 2,117, Level: 10
    Achievements:
    7 years registered
    Join Date
    Jul 2007
    India
    Posts
    141
    Points
    2,117
    Level
    10
    in spice code, give the command .op and .tf (transfer function) of output voltage.
    u can see the input and output impedances seen in the output listing file.
    •   Alt25th July 2007, 12:01
      advertising
  3. #3
    Junior Member level 3
    Points: 1,984, Level: 10
    Join Date
    Jan 2006
    Posts
    26
    Points
    1,984
    Level
    10
    dear analog_prodigy
    Do you know another method at the spectre?
    •   Alt26th July 2007, 03:38
      advertising
  4. #4
    Full Member level 4
    Points: 3,843, Level: 14
    Join Date
    Apr 2005
    Posts
    235
    Points
    3,843
    Level
    14
    in spectre, maintian the DC input level and add a ac current at the output node, run ac simulation and get the ac voltage magnitude of the output node, the output resistance is equal to the ac voltage magnitude devided by the ac current, if the ac current is set to be 1A, then the output resistance will just be equal to the ac magnitude.
