Any function in MATLAB to define function from sample values
gunturikishore
Full Member level 2
INDIA GANDHINAGAR
Is there any such function that provides a mathematical function in MATLAB when the sample vaues are given in numericals. Thanks for any help in advance.
Re: Any function in MATLAB to define function from sample va
Have you looked at the interpolation functions?
It depends on the problem you are going to solve.
1) If you intend just to apply any function (according to a certain criterion) in order to link the all the knots (all samples) then interpolation should be used. Matlab provides you with polynomials of various degrees (i's unlikely to choose too high degrees because of the too much time expenditure), splines, shape-preserving interpolation and special functions, available in Matlab's description.
2) If you need to find out the function that fits the data, but at the same time doesn't connect all the knots choose approximation techniques, for example polynomial approximation with RMS criterion - function polyfit
With respect.
Dmitrij
If you simply need to "connect the dots", try using MATLAB's built-in spline functions, such as interp1, pchip and spline.
If you need to fit a model to your data (a least-squares curve-fit, for instance, which won't necessarily pass through any of the given data points), then things are more complicated. A simple, least-squares linear fit can be accomplished via MATLAB's backslash operator, '\'. See, for instance: https://matlabdatamining.blogspot.com/2007/04/linear-regression-in-matlab.html
Some nonlinear models can be achieved by simply adding nonlinear terms to a linear fit (fit versus a constant, x and log of x, rather than just x). Polynomial fits can be performed by using MATLAB's polyfit function.
-Will Dwinnell
