+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Newbie level 6
    Points: 1,153, Level: 7
    Join Date
    Nov 2006
    Posts
    13
    Points
    1,153
    Level
    7
    hfss lumped port
    A lumped port can be assigned to a rectangle. Does the size of the rectangle affect the simulation results? Should it be as small as possible?
  2. #2
    Full Member level 1
    Points: 2,153, Level: 10
    nhomuathu_hanoi's Avatar
    Join Date
    Apr 2007
    Hometown
    Posts
    95
    Points
    2,153
    Level
    10
    sizing lumped port in hfss
    Hi waltzsu,
    You can refer to following link and find the attachments name: "HFSS_full_book_v10" and "Port_tutorial"
    http://www.edaboard.com/ftopic82440-0.html
    They will tell you how to define a lumped port and size of the port.
    Hope it helps you
    2 members found this post helpful.
    •   Alt11th July 2007, 04:06
      advertising
  3. #3
    Newbie level 6
    Join Date
    Nov 2006
    Posts
    13
    Points
    1,153
    Level
    7
    lumped port
    Thank you very much. I have downloaded the port tutorial. It is helpful. But I did not have enough points to download the full book.
    anyway, Thank you very much.
    1 members found this post helpful.
    •   Alt11th July 2007, 17:58
      advertising
  4. #4
    Full Member level 1
    Join Date
    Apr 2007
    Hometown
    Posts
    95
    Points
    2,153
    Level
    10
    hfss lumped port size
    hi waltzsu,
    Try with HFSS_V10_full_book at:
    http://www.megaupload.com/?d=LRDGNI0G
    have fun!
    •   Alt12th July 2007, 01:39
      advertising
  5. #5
    Newbie level 6
    Join Date
    Nov 2006
    Posts
    13
    Points
    1,153
    Level
    7
    deembed hfss
    thank you so much.
  6. #6
    Full Member level 2
    Points: 3,382, Level: 13
    Join Date
    Feb 2005
    Posts
    143
    Points
    3,382
    Level
    13
    when to use lumped port
    waltzu:
    The larger the rectangle, the bigger the electromagnetic discontinuity to your lumped port. The key is that the lumped port is on an ideal wire that connects one metal body to another body or PEC boundary condition. So you will always have that discontinuity as current flows from the big body down to the connection point of the ideal wire.
    There is no way to calibrate out, or de-embed that discontinuity in HFSS. So the technique works well as long as your frequency is low enough so that the discontinuity doesn't throw your simulation results.
    --Max
  7. #7
    Full Member level 5
    Points: 2,939, Level: 12
    Join Date
    Jul 2004
    Posts
    250
    Points
    2,939
    Level
    12
    size lumped port
    in hfss size doesnt matter because lumped port just define the type of excitation....b/w the ports so not to worry abt the size
  8. #8
    Full Member level 2
    Points: 3,334, Level: 13
    Join Date
    Oct 2003
    Posts
    142
    Points
    3,334
    Level
    13
    hfss deembed
    Quote Originally Posted by akedar
    I'm agree fully.
    Also, with the Lumped Port you can execute one-mode simulation only.
  9. #9
    Full Member level 2
    Join Date
    Feb 2005
    Posts
    143
    Points
    3,382
    Level
    13
    what are lumped ports
    akedar:
    Your statement really depends on your application. If you want an excitation for a small body at low frequency, then I would agree that the error introduced by using a lumped port is small enough that it can be neglected for practical purposes.
    But for most practical microwave design, I believe this is not true.
    For example, try taking a 50 ohm transmission line on 100 um GaAs substrate. Simulate this example as a reference result.
    Next, slice a 100um long section from the middle, and put a lumped port on each side of your gap. Simulate this example (1 waveport on each end, and then the 2 lumped ports in the middle). Simulate a 100um section of the transmission line in another example (you will need to use reference planes from the larger original problem so that you don't get your waveports too close together).
    Cascade the results of your 100um transmission line with the lumped ports from the 4-port example, so you get a model that should be equivalent to the longer, non-segmented transmission line.
    This example is similar to the case on an IC where you want to simulate circuitry on both sides of the transistor.
    I think you will agree that lumped ports do indeed have limitations if you use them in situations where the error that they contribute to the problem negates their value in modeling.
    --Max
    •   Alt16th July 2007, 14:59
      advertising
  10. #10
    Junior Member level 3
    Points: 1,316, Level: 8
    Join Date
    Aug 2006
    Posts
    28
    Points
    Level
    8
    hfss lump port
    If the size of the lumped size is too big, you may have to change the dimension of the simulated structure in order to leave the space to the port. In this case, the size of the lumped size does matter.
