how to split bus going to different blocks?
mask_layout
verilog split bus
I have 3 blocks one with
output [31:0]
second block with input [8:0]
third block with input [31:9]
please help,
I want to connect the output pin to second and third block however
how to do it,...
wire [31:9] NETX;
wire [8:0] NETX;
will not work / conflicts.
Thanks,
mask_layout
verilog bus split
Declare it as one vector
wire [31:0] netx and use [31:9]netx for one block and [8:0]netx for another block as input
how to splir a bus in vhdl
its depend s on HDL ... if you are using VHDL then you can use alias keyword...
for ex..
IR : std_logic_vector(18 downto 0)
and you want a variable rd1_erg which should be a part of IR from 11-13 then you can declare this as like
alias rd1_reg:reg_addr is IR(13 downto 11)
i think it will be helpful for you... if i helped you plz click on the help option.
thanks & regards
Deepak
how to split bus of wires in vhdl
thanks guys.. i dont really work on schematics and just trying to hack my verilog and this is confusing to me...
please let me know if i understand you correctly.
below are the relevant part of my verilog code problem:
module testcrap ( TCLOCK,TRESET,hapi, bdayo);
// Module I/O Signals
    input  TCLOCK, TRESET;
    input  [31:0] hapi;
    output [15:0]bdayo;
    wire [31:0] NETX;
    wire [6:0]  IN;
    wire [15:0] pass;
//CONTROL BLOCK1
block1 block1 (
   .CLK    (TCLOCK),
   .RST    (TRESET),
   .datab  (NETX[8:0]), // this goes to ctrl block
   .tr1    (IN[5:0]),   // goes to block2
   .tr2    (IN[6])      // goes to block2
//CONTROL BLOCK2
block2 block2 (
   .CLK    (TCLOCK),
   .RST    (TRESET),
   .datab  (NETX[31:9]), // connects to ctrl block
   .in2    (IN),         //connects to block1 IN[6:0]
   .pass_o (pass)       // connect to ctrl block
controlblock control (
   .CLK    (TCLOCK),
   .RST    (TRESET),
   .hapi   (hapi),  //input
   .out    (bdayo), //output
   .pasi   (pass),  // recives from blk2
   .netx   (NETX)   //recieves from blk 1 &2
Please notice NETX comes from block1 and 2 and goes to one bus in control block.
Also block1 has tr1 and tr2 that goes to block2... also a bus joining bus... :(
Whats wrong or missing in my code?
Please help.. thanks in advance.
ver-149 design compiler
If you're still getting errors with NETX, make sure you have the correct bit ranges.
8:0 is 9 bits
31:9 is 23 bits
If the two inputs are 8- and 24-bits, the bit ranges are
7:0
31:8
verilog break bus
Thanks... Yup missed that bit ranges. thanks tkbits...
however, it looks like im doing some wrong sintax or grouping here...
In dc compiler im getting lots of errors on the code:
can some body help understand please
errors:
Symbol SLEPP not included in portlist (VER-149)
Base of subscript operator EVENT_NFO must be a vector(VER-194)
Illegal part select of memory 'EVENT_NFO'. (VER-963)
One problem i have is that it seems it wont take
ranges like
inside a block...
what is the right syntax for this?
I want to wire different signals from one block into a group of buswire in another block..
How do i do this?
