Help ISP loader circuit for AT89sxx microcontroller series
hbaocr
Full Member level 4
Hochiminh City university of technology (VietNam)
hello
I use ISP_Flash progammer V3.0 by asimkhan
I use winXp SP2 and my main board is asus p5ld2
I have just learned microcontroller! I made ISP loader circuit but It is not running and generate errors such as " Device Signature did not math? do you want ot continue" and then it appear mesage box "no response from Uc.." I don't know I have which mistakes ! Thank you very much!
here are the schematic and *.max file I build with orcad
Please help me to test Errors! Thank you very much
Re: Help ISP loader circuit for AT89sxx microcontroller ser
use ver 3.7 isp
and goto option set default
then try and enjoy.
your cable from the printer port is too long. this is a common problem with this programmer.
hai i am srikanth .. i am also facing the same problem ..
when i try to connect it show "no response from the uc".
pls help me the ciruit diagram i used is here..
