shahid78
Full Member level 5
04 Jul 2007 18:08 dipole antenna close to metal ground plane
i am using CST to model dipole antenna which is lying parallel to metal ground plane. i want to study the effect on antenna characteristic by varying the height of dipole over ground plane.
when i simulated this dipole antenna for 2.4Ghz centre frequence and place it very close to ground plane 3mm to be exact i get badly matched dipole shown by poor s11 parameter. however when i check the farfield pattern at 2.4 ghz , the directivity is around 8dbi which is the same when i place it far above ground and its giving radiation pattern and wide main lobe with maximum in θ=0 degree.
can anyone explain this why this is happening because in my view if antenna's
s11 parameter is not good it should not radiate efficiently as it is not properly matced and its directivity should be very low.
any help would be highly appreciated.
thanks
thanks
